Red light the whole time
Postby Austin » Sun Feb 10, 2013 7:46 pm
Dear all,
I purchased the TBS TBS5680 DVB-C Single in Germany last week. I bought it for my Synology NAS 112j as it is compatible with DVBLink software.
But the TBS it is not found by NAS. So I tried to connect it to my PC, which works, the USB device is detected. But no channels are found in Scan. The TBS5680 has a red led the whole time. I could not find any information what that red light means. But the PC software tells me that it has only 1% signal strength. Well, if I connect the same Cable directly to my Samsung LED TV with DVB-C tuner it works perfectly. So I guess that the signal should be there.
So, what should I do. Could it be that the TBS5680 is not working properly, or am I doing anything wrong...
Thanks a lot for you support and help!
Austin
Re: Red light the whole time
Postby steven » Mon Feb 11, 2013 12:57 pm
Hi Austin
Would you mind having a try with our OEM-DVBDream in your PC to have a check with TBS5680?
Kind Regars
Postby Austin » Mon Feb 11, 2013 4:27 pm
Hi steven,
Yes I would try that, what do I have to do?
I tried it with TBS viewer and will install DVB dream this evening when I am at home again.
Austin
Postby hans » Tue Jul 01, 2014 10:09 pm
Hello Steven,
I use the TBS5680 in combination with the DS214play NAS.
The connection is made with the front USB connection of the NAS.
However I get a red light all the time.
What is wrong with the connection ?
hans
