5680 vs. 5881: differences? Recommendation?
Postby JoePS » Mon Jan 08, 2018 9:49 pm
It would be very helpful, if you could provide me with some information about the differences between TBS5881 and TBS5680.
Is TBS5881 the newer model?
TBS5881 recommended?
Thanks in advance,
JoePS
Intel NUC 5i5RYH, Win. 10 Pro 64; TechnoTrend TT-connect CT-3650 CI; AlphaCrypt Classic P/N 901650 R1.4 mit One4All 1.0 (NDS Card V23, Unitymedia Kabel BW), DVBViewer & Media Server & Rec. Service App
JoePS
Re: 5680 vs. 5881: differences? Recommendation?
Postby steven » Tue Jan 09, 2018 11:31 am
Yea 5881 is the new one which support DVB-T/C at the same time . 5680 only support DVB-C
Return to DVB-C TV Tuner CI USB TBS5680
