TBS6618 - does not work with linux driver under Ubuntu 12.10
Postby cduerr » Sat Feb 23, 2013 2:08 am
my TBS6618 works fine under Windows 7 (Pro, 64bit) on the same machine.
After installing the linux drivers the syslog and lsmod indicate the modules have been loaded and the card should be ready, however, scanning for services in my local cable operator's network does not find any services (I have to use w_scan to get results as i need the card for vdr. I also put the card into a working vdr, but that vdr is not able to tune, either, despite it already has a working channel list from another DVBC card on the same signal). I doublechecked cable and card, both work fine under Windows on the same machine.
I use http://www.tbsdtv.com/download/document ... 130127.zip.
I installed as root, tar xvjf, cd folder, cp dvb-usb-tbsqbox-dvbc.fw /lib/firmware, ./v4l/tbs-x86_64.sh, make && make install, reboot.
The logs are attached as requested. Just let me know what you need and i happily provide you with more information. The Ubuntu 12.10 is a fresh install, just for the purpose of troubleshooting the issue.
If you'd ask me, i am not sure the firmware gets loaded at all (renaming dvb-usb-tbsqbox-dvbc.fw and rebooting does not change anything in the behavior of the card and no error appears in the dmesg).
On a different machine, i have the same behavior. On both machines, with a different Ubuntu (12.04), i have the same behavior.
Can you please advice what i am doing wrong? Thank you!
log_tbs.tar
(110 KiB) Downloaded 1471 times
cduerr
Re: TBS6618 - does not work with linux driver under Ubuntu 1
Postby SergioDanielG » Sat Feb 23, 2013 4:05 am
Hi cduerr.
From your lscpi_log
02:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
   Subsystem: Device [6618:0001]
   Kernel modules: saa716x_tbs-dvb
and from your dmesg_log
[   10.297409] Registered IR keymap rc-tbs-nec
[   10.297474] input: saa716x IR (TurboSight TBS 6618) as /devices/pci0000:00/0000:00:14.0/0000:02:00.0/rc/rc0/input6
[   10.297705] rc0: saa716x IR (TurboSight TBS 6618) as /devices/pci0000:00/0000:00:14.0/0000:02:00.0/rc/rc0
[   10.298815] input: MCE IR Keyboard/Mouse (saa716x) as /devices/virtual/input/input7
[   10.298942] rc rc0: >lirc_dev: driver ir-lirc-codec (saa716x) registered at minor = 0
[   10.298946] DVB: registering new adapter (SAA716x dvb adapter)
[   10.553600] TurboSight TBS6618 DVB-C card MAC=xx:xx:xx:xx:xx:xx
[   10.568922] tbsci: Initializing TBS 6618 CI slot
[   10.569038] tbsci: Adapter 0 CI slot initialized
[   10.569041] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6618 DVBC frontend)...
All looks good about your card.
Can you post output of "ls -l /dev/dvb", full w_scan command and output of these command?
Best regards.
SergioDanielG
Postby cduerr » Sat Feb 23, 2013 5:34 am
Hi SergioDanielG,
thanks for looking into the issue. Here it is:
w_scan -f c
w_scan version 20121111 (compiled for DVB API 5.6)
guessing country 'DE', use -c <country> to override
using settings for GERMANY
DVB cable
DVB-C
scan type CABLE, channellist 7
output format vdr-1.6
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
   /dev/dvb/adapter0/frontend0 -> CABLE "TurboSight TBS 6618 DVBC frontend": good :-)
Using CABLE frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'TurboSight TBS 6618 DVBC frontend' supports
INVERSION_AUTO
QAM_AUTO
FEC_AUTO not supported, trying FEC_NONE.
FREQ (47.00MHz ... 870.00MHz)
This dvb driver is *buggy*: the symbol rate limits are undefined - please report to linuxtv.org
73000: sr6900 (time: 00:01) sr6875 (time: 00:04)
81000: sr6900 (time: 00:07) sr6875 (time: 00:09)
113000: sr6900 (time: 00:12) sr6875 (time: 00:14)
121000: sr6900 (time: 00:17) sr6875 (time: 00:19)
129000: sr6900 (time: 00:22) sr6875 (time: 00:24)
137000: sr6900 (time: 00:27) sr6875 (time: 00:29)
145000: sr6900 (time: 00:32) sr6875 (time: 00:34)
153000: sr6900 (time: 00:37) sr6875 (time: 00:39)
161000: sr6900 (time: 00:42) sr6875 (time: 00:44)
169000: sr6900 (time: 00:47) sr6875 (time: 00:49)
314000: sr6900 (time: 00:52) sr6875 (time: 00:54)
322000: sr6900 (time: 00:57) sr6875 (time: 00:59)
330000: sr6900 (time: 01:02) sr6875 (time: 01:04)
338000: sr6900 (time: 01:07) sr6875 (time: 01:09)
346000: sr6900 (time: 01:12) sr6875 (time: 01:14)
354000: sr6900 (time: 01:17) sr6875 (time: 01:19)
362000: sr6900 (time: 01:22) sr6875 (time: 01:24)
370000: sr6900 (time: 01:27) sr6875 (time: 01:29)
378000: sr6900 (time: 01:32) sr6875 (time: 01:34)
386000: sr6900 (time: 01:37) sr6875 (time: 01:39)
394000: sr6900 (time: 01:42) sr6875 (time: 01:44)
402000: sr6900 (time: 01:47) sr6875 (time: 01:49)
410000: sr6900 (time: 01:52) sr6875 (time: 01:54)
418000: sr6900 (time: 01:57) sr6875 (time: 01:59)
426000: sr6900 (time: 02:02) sr6875 (time: 02:04)
434000: sr6900 (time: 02:07) sr6875 (time: 02:09)
442000: sr6900 (time: 02:12) sr6875 (time: 02:14)
450000: sr6900 (time: 02:17) sr6875 (time: 02:19)
458000: sr6900 (time: 02:22) sr6875 (time: 02:24)
466000: sr6900 (time: 02:27) sr6875 (time: 02:29)
474000: sr6900 (time: 02:32) sr6875 (time: 02:34)
482000: sr6900 (time: 02:37) sr6875 (time: 02:39)
490000: sr6900 (time: 02:42) sr6875 (time: 02:44)
498000: sr6900 (time: 02:47) sr6875 (time: 02:49)
506000: sr6900 (time: 02:52) sr6875 (time: 02:54)
514000: sr6900 (time: 02:57) sr6875 (time: 02:59)
522000: sr6900 (time: 03:02) sr6875 (time: 03:04)
530000: sr6900 (time: 03:07) sr6875 (time: 03:09)
538000: sr6900 (time: 03:12) sr6875 (time: 03:14)
546000: sr6900 (time: 03:17) sr6875 (time: 03:19)
554000: sr6900 (time: 03:22) sr6875 (time: 03:24)
562000: sr6900 (time: 03:27) sr6875 (time: 03:29)
570000: sr6900 (time: 03:32) sr6875 (time: 03:34)
578000: sr6900 (time: 03:37) sr6875 (time: 03:39)
586000: sr6900 (time: 03:42) sr6875 (time: 03:44)
594000: sr6900 (time: 03:47) sr6875 (time: 03:49)
602000: sr6900 (time: 03:52) sr6875 (time: 03:54)
610000: sr6900 (time: 03:57) sr6875 (time: 03:59)
618000: sr6900 (time: 04:02) sr6875 (time: 04:04)
626000: sr6900 (time: 04:07) sr6875 (time: 04:09)
634000: sr6900 (time: 04:12) sr6875 (time: 04:14)
642000: sr6900 (time: 04:17) sr6875 (time: 04:19)
650000: sr6900 (time: 04:22) sr6875 (time: 04:24)
658000: sr6900 (time: 04:27) sr6875 (time: 04:29)
666000: sr6900 (time: 04:32) sr6875 (time: 04:34)
674000: sr6900 (time: 04:37) sr6875 (time: 04:39)
682000: sr6900 (time: 04:42) sr6875 (time: 04:44)
690000: sr6900 (time: 04:47) sr6875 (time: 04:50)
698000: sr6900 (time: 04:52) sr6875 (time: 04:55)
706000: sr6900 (time: 04:57) sr6875 (time: 05:00)
714000: sr6900 (time: 05:02) sr6875 (time: 05:05)
722000: sr6900 (time: 05:07) sr6875 (time: 05:10)
730000: sr6900 (time: 05:12) sr6875 (time: 05:15)
738000: sr6900 (time: 05:17) sr6875 (time: 05:20)
746000: sr6900 (time: 05:22) sr6875 (time: 05:25)
754000: sr6900 (time: 05:27) sr6875 (time: 05:30)
762000: sr6900 (time: 05:32) sr6875 (time: 05:35)
770000: sr6900 (time: 05:37) sr6875 (time: 05:40)
778000: sr6900 (time: 05:42) sr6875 (time: 05:45)
786000: sr6900 (time: 05:47) sr6875 (time: 05:50)
794000: sr6900 (time: 05:52) sr6875 (time: 05:55)
802000: sr6900 (time: 05:57) sr6875 (time: 06:00)
810000: sr6900 (time: 06:02) sr6875 (time: 06:05)
818000: sr6900 (time: 06:07) sr6875 (time: 06:10)
826000: sr6900 (time: 06:12) sr6875 (time: 06:15)
834000: sr6900 (time: 06:17) sr6875 (time: 06:20)
842000: sr6900 (time: 06:22) sr6875 (time: 06:25)
850000: sr6900 (time: 06:27) sr6875 (time: 06:30)
858000: sr6900 (time: 06:32) sr6875 (time: 06:35)
73000: sr6900 (time: 06:37) sr6875 (time: 06:40)
81000: sr6900 (time: 06:42) sr6875 (time: 06:45)
113000: sr6900 (time: 06:47) sr6875 (time: 06:50)
121000: sr6900 (time: 06:52) sr6875 (time: 06:55)
129000: sr6900 (time: 06:57) sr6875 (time: 07:00)
137000: sr6900 (time: 07:02) sr6875 (time: 07:05)
145000: sr6900 (time: 07:07) sr6875 (time: 07:10)
153000: sr6900 (time: 07:12) sr6875 (time: 07:15)
161000: sr6900 (time: 07:17) sr6875 (time: 07:20)
169000: sr6900 (time: 07:22) sr6875 (time: 07:25)
314000: sr6900 (time: 07:27) sr6875 (time: 07:30)
322000: sr6900 (time: 07:32) sr6875 (time: 07:35)
330000: sr6900 (time: 07:37) sr6875 (time: 07:40)
338000: sr6900 (time: 07:42) sr6875 (time: 07:45)
346000: sr6900 (time: 07:47) sr6875 (time: 07:50)
354000: sr6900 (time: 07:52) sr6875 (time: 07:55)
362000: sr6900 (time: 07:57) sr6875 (time: 08:00)
370000: sr6900 (time: 08:02) sr6875 (time: 08:05)
378000: sr6900 (time: 08:07) sr6875 (time: 08:10)
386000: sr6900 (time: 08:12) sr6875 (time: 08:15)
394000: sr6900 (time: 08:17) sr6875 (time: 08:20)
402000: sr6900 (time: 08:22) sr6875 (time: 08:25)
410000: sr6900 (time: 08:27) sr6875 (time: 08:30)
418000: sr6900 (time: 08:32) sr6875 (time: 08:35)
426000: sr6900 (time: 08:37) sr6875 (time: 08:40)
434000: sr6900 (time: 08:42) sr6875 (time: 08:45)
442000: sr6900 (time: 08:47) sr6875 (time: 08:50)
450000: sr6900 (time: 08:52) sr6875 (time: 08:55)
458000: sr6900 (time: 08:57) sr6875 (time: 09:00)
466000: sr6900 (time: 09:02) sr6875 (time: 09:05)
474000: sr6900 (time: 09:07) sr6875 (time: 09:10)
482000: sr6900 (time: 09:12) sr6875 (time: 09:15)
490000: sr6900 (time: 09:17) sr6875 (time: 09:20)
498000: sr6900 (time: 09:22) sr6875 (time: 09:25)
506000: sr6900 (time: 09:27) sr6875 (time: 09:30)
514000: sr6900 (time: 09:33) sr6875 (time: 09:35)
522000: sr6900 (time: 09:38) sr6875 (time: 09:40)
530000: sr6900 (time: 09:43) sr6875 (time: 09:45)
538000: sr6900 (time: 09:48) sr6875 (time: 09:50)
546000: sr6900 (time: 09:53) sr6875 (time: 09:55)
554000: sr6900 (time: 09:58) sr6875 (time: 10:00)
562000: sr6900 (time: 10:03) sr6875 (time: 10:05)
570000: sr6900 (time: 10:08) sr6875 (time: 10:10)
578000: sr6900 (time: 10:13) sr6875 (time: 10:15)
586000: sr6900 (time: 10:18) sr6875 (time: 10:20)
594000: sr6900 (time: 10:23) sr6875 (time: 10:25)
602000: sr6900 (time: 10:28) sr6875 (time: 10:30)
610000: sr6900 (time: 10:33) sr6875 (time: 10:35)
618000: sr6900 (time: 10:38) sr6875 (time: 10:40)
626000: sr6900 (time: 10:43) sr6875 (time: 10:45)
634000: sr6900 (time: 10:48) sr6875 (time: 10:50)
642000: sr6900 (time: 10:53) sr6875 (time: 10:55)
650000: sr6900 (time: 10:58) sr6875 (time: 11:00)
658000: sr6900 (time: 11:03) sr6875 (time: 11:05)
666000: sr6900 (time: 11:08) sr6875 (time: 11:10)
674000: sr6900 (time: 11:13) sr6875 (time: 11:15)
682000: sr6900 (time: 11:18) sr6875 (time: 11:20)
690000: sr6900 (time: 11:23) sr6875 (time: 11:25)
698000: sr6900 (time: 11:28) sr6875 (time: 11:30)
706000: sr6900 (time: 11:33) sr6875 (time: 11:35)
714000: sr6900 (time: 11:38) sr6875 (time: 11:40)
722000: sr6900 (time: 11:43) sr6875 (time: 11:45)
730000: sr6900 (time: 11:48) sr6875 (time: 11:50)
738000: sr6900 (time: 11:53) sr6875 (time: 11:55)
746000: sr6900 (time: 11:58) sr6875 (time: 12:00)
754000: sr6900 (time: 12:03) sr6875 (time: 12:05)
762000: sr6900 (time: 12:08) sr6875 (time: 12:10)
770000: sr6900 (time: 12:13) sr6875 (time: 12:15)
778000: sr6900 (time: 12:18) sr6875 (time: 12:20)
786000: sr6900 (time: 12:23) sr6875 (time: 12:25)
794000: sr6900 (time: 12:28) sr6875 (time: 12:30)
802000: sr6900 (time: 12:33) sr6875 (time: 12:35)
810000: sr6900 (time: 12:38) sr6875 (time: 12:40)
818000: sr6900 (time: 12:43) sr6875 (time: 12:45)
826000: sr6900 (time: 12:48) sr6875 (time: 12:50)
834000: sr6900 (time: 12:53) sr6875 (time: 12:55)
842000: sr6900 (time: 12:58) sr6875 (time: 13:00)
850000: sr6900 (time: 13:03) sr6875 (time: 13:05)
858000: sr6900 (time: 13:08) sr6875 (time: 13:10)
ERROR: Sorry - i couldn't get any working frequency/transponder
 Nothing to scan!!
ls -l /dev/dvb
insgesamt 0
drwxr-xr-x 2 root root 140 Feb 22 21:52 adapter0
My cable provider uses a symbol rate of 6900MSym and QAM64 and QAM256.
cduerr
Postby SergioDanielG » Sat Feb 23, 2013 8:29 am
Hi cduerr.
I can't found nothing strange, unfortunatelly I haven't got any cable service to try by my self, but please try with this
w_scan -fc DE -o 7 -v -F -t 3 -Q 0 -S 0
Then change modulation and try again
w_scan -fc DE -o 7 -v -F -t 3 -Q 1 -S 0
Best regards.
SergioDanielG
Postby cduerr » Sat Feb 23, 2013 5:12 pm
Unfortunately, no change.
Attached are the logs of the different commands (modulation: QAM 64, 256 and 128).
What's next?
wscan_tbs_log.tar
(20 KiB) Downloaded 1386 times
cduerr
Postby cody » Mon Feb 25, 2013 4:49 am
@cduerr
it's hard to tell why VDR doesn't lock for you based on the information you provided, but the problem with 'w_scan' is obvious - it's actually problem with your 'w_scan' build - as from your log it says "w_scan version 20121111 (compiled for DVB API 5.6)".
so, i'm suggesting to try the following:
* download for example 'w_scan-20120605' (i have tested that version) from here:
http://pkgs.fedoraproject.org/repo/pkgs ... 05.tar.bz2
and build it:
# tar xjvf w_scan-20120605.tar.bz2
# cd w_scan-20120605
w_scan-20120605# ./configure
w_scan-20120605# make
and then run that newly build 'w_scan' and see if it will report proper DVB API version for TBS drivers:
w_scan-20120605# ./w_scan
w_scan version 20120605 (compiled for DVB API 5.3)
if that doesn't help, please, let me know what is the output of:
# cat /usr/include/linux/dvb/version.h
in your Linux installation. in fact if the above doesn't help my next suggestion is to replace your "/usr/include/linux/dvb/version.h" with the one from TBS Linux driver package and rebuild 'w_scan'. basically, the goal is to have proper build of 'w_scan' that reports "(compiled for DVB API 5.3)".
Postby cduerr » Mon Feb 25, 2013 5:56 am
thanks for your help. I made a backup of /usr/include/linux/dvb/version.h and replaced it with the copy from the TBS driver package, made a make distclean and rebuild the new w_scan as you indicated. This version now reports "built for API 5.3". But still no services found:
root@ubuntu:~/wscan2012/w_scan-20120605# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for gawk... (cached) mawk
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for stdint.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for unistd.h... (cached) yes
checking for inline... inline
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint8_t... yes
checking for error_at_line... yes
checking for GNU libc compatible malloc... yes
checking for memset... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strtoul... yes
checking for linux/dvb/frontend.h presence... yes
checking for linux/dvb/frontend.h usability (FE_CAN_2G_MODULATION)... yes
checking for linux/dvb/frontend.h usability (DVB-T2, DVB API >= v5.3)... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: executing depfiles commands
root@ubuntu:~/wscan2012/w_scan-20120605# make
make  all-am
make[1]: Betrete Verzeichnis '/root/wscan2012/w_scan-20120605'
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT atsc_psip_section.o -MD -MP -MF .deps/atsc_psip_section.Tpo -c -o atsc_psip_section.o atsc_psip_section.c
mv -f .deps/atsc_psip_section.Tpo .deps/atsc_psip_section.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT countries.o -MD -MP -MF .deps/countries.Tpo -c -o countries.o countries.c
mv -f .deps/countries.Tpo .deps/countries.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT descriptors.o -MD -MP -MF .deps/descriptors.Tpo -c -o descriptors.o descriptors.c
mv -f .deps/descriptors.Tpo .deps/descriptors.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT diseqc.o -MD -MP -MF .deps/diseqc.Tpo -c -o diseqc.o diseqc.c
mv -f .deps/diseqc.Tpo .deps/diseqc.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-dvbscan.o -MD -MP -MF .deps/dump-dvbscan.Tpo -c -o dump-dvbscan.o dump-dvbscan.c
mv -f .deps/dump-dvbscan.Tpo .deps/dump-dvbscan.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-kaffeine.o -MD -MP -MF .deps/dump-kaffeine.Tpo -c -o dump-kaffeine.o dump-kaffeine.c
mv -f .deps/dump-kaffeine.Tpo .deps/dump-kaffeine.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-vdr.o -MD -MP -MF .deps/dump-vdr.Tpo -c -o dump-vdr.o dump-vdr.c
mv -f .deps/dump-vdr.Tpo .deps/dump-vdr.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-xine.o -MD -MP -MF .deps/dump-xine.Tpo -c -o dump-xine.o dump-xine.c
mv -f .deps/dump-xine.Tpo .deps/dump-xine.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-mplayer.o -MD -MP -MF .deps/dump-mplayer.Tpo -c -o dump-mplayer.o dump-mplayer.c
mv -f .deps/dump-mplayer.Tpo .deps/dump-mplayer.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dump-vlc-m3u.o -MD -MP -MF .deps/dump-vlc-m3u.Tpo -c -o dump-vlc-m3u.o dump-vlc-m3u.c
mv -f .deps/dump-vlc-m3u.Tpo .deps/dump-vlc-m3u.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT dvbscan.o -MD -MP -MF .deps/dvbscan.Tpo -c -o dvbscan.o dvbscan.c
mv -f .deps/dvbscan.Tpo .deps/dvbscan.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT lnb.o -MD -MP -MF .deps/lnb.Tpo -c -o lnb.o lnb.c
mv -f .deps/lnb.Tpo .deps/lnb.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT parse-dvbscan.o -MD -MP -MF .deps/parse-dvbscan.Tpo -c -o parse-dvbscan.o parse-dvbscan.c
mv -f .deps/parse-dvbscan.Tpo .deps/parse-dvbscan.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT satellites.o -MD -MP -MF .deps/satellites.Tpo -c -o satellites.o satellites.c
mv -f .deps/satellites.Tpo .deps/satellites.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT scan.o -MD -MP -MF .deps/scan.Tpo -c -o scan.o scan.c
mv -f .deps/scan.Tpo .deps/scan.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT section.o -MD -MP -MF .deps/section.Tpo -c -o section.o section.c
mv -f .deps/section.Tpo .deps/section.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT iconv_codes.o -MD -MP -MF .deps/iconv_codes.Tpo -c -o iconv_codes.o iconv_codes.c
mv -f .deps/iconv_codes.Tpo .deps/iconv_codes.Po
gcc -DHAVE_CONFIG_H -I.    -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2 -MT char-coding.o -MD -MP -MF .deps/char-coding.Tpo -c -o char-coding.o char-coding.c
mv -f .deps/char-coding.Tpo .deps/char-coding.Po
gcc -Wall -Wextra -Wno-comment -Wswitch-default -Wno-unused-parameter -g -O2   -o w_scan atsc_psip_section.o countries.o descriptors.o diseqc.o dump-dvbscan.o dump-kaffeine.o dump-vdr.o dump-xine.o dump-mplayer.o dump-vlc-m3u.o dvbscan.o lnb.o parse-dvbscan.o satellites.o scan.o section.o iconv_codes.o char-coding.o
make[1]: Verlasse Verzeichnis '/root/wscan2012/w_scan-20120605'
root@ubuntu:~/wscan2012/w_scan-20120605# make install
 /bin/mkdir -p '/usr/local/bin'
  /usr/bin/install -c w_scan '/usr/local/bin'
 /bin/mkdir -p '/usr/local/share/man/man1'
 /usr/bin/install -c -m 644 doc/w_scan.1 '/usr/local/share/man/man1'
root@ubuntu:~/wscan2012/w_scan-20120605# w_scan -fc DE -o 7 -v -F -t 3 -Q 0 -S 0 > wscan_tbs_q0_withnewwscanbuild2_log
get_user_country: lang id = DE
DVB cable
DVB-C
output format vdr-1.7
Using DVB API 5.3
INVERSION_AUTO
QAM_AUTO
73000: sr6900 (time: 00:02)
858000: sr6900 (time: 03:17)
 Nothing to scan!!
cduerr
Postby cduerr » Thu Feb 28, 2013 3:11 am
Any more support? It is still not working.
cduerr
Postby cody » Mon Mar 04, 2013 8:56 pm
sorry, for the late reply - please, when post to the forum about Linux problems that obliviously required help from our support, send email to euro_support@tbsdtv.com with CC to support@tbsdtv.com, as it's explained in the 'How to report a problem with TBS Linux drivers':
viewtopic.php?f=77&t=2194
otherwise there is quite good chance you won't receive reply, because no one actually noticed your problem report.
anyway, please, test and tell us what happens - if you create "dvbc.conf" configuration file, which is text file just containing one line like this:
C 130000000 6900000 NONE QAM64
where 130MHz is replaced with valid frequency for your cable network, as well 6900 kSps and QAM64 are replaced with valid values for your signal. in such case if you run:
# scan dvbc.conf
does it work properly? also, it it works properly why not generate "channel.conf" in that way, i.e. using 'scan' instead using 'w_scan' which fails for you. also, i'm going to investigate what's going on with 'w_scan', but it should work too.
Postby cduerr » Tue Mar 05, 2013 6:39 am
Fascinating. I have never ever had any issues with w_scan, but you are absolutely right. Using scan (from dvbapps package) and providing a valid initial transponder info, the network scan showed up all services on my local cable operator. There obviously must be something turning wrong when operating w_scan with your card. Anyway: I then installed X and vdr and was able to verify it is working end-to-end, but found one more issue (i will open a new topic for this).
Thanks a million!
cduerr
