Tv Tuner usb TBS 5580 e Cam Tv Sat
Postby Plasma70 » Tue Jan 12, 2021 11:03 pm
Hi, I recently bought a TBS 5580 tv tuner, but when I insert my tvsat tv cam the software like dvb-drem- smart dvb - prog dvb don't see it.
How can I make it work?
Should it be activated? Thanks
Photo of my cam:
https://mega.nz/file/f7ggFBzS#39hpEL...98cKDk8X0EZFfg
Plasma70
Re: Tv Tuner usb TBS 5580 e Cam Tv Sat
Postby steven » Fri Jan 15, 2021 9:44 am
Hi Sir
Possible setup teamview remote and send your CAM picture to our support@tbsdtv.com
Postby Plasma70 » Thu Feb 04, 2021 7:10 pm
You don't have a setup guide with instructions ?
Plasma70
Postby steven » Sun Feb 21, 2021 2:15 pm
for dvbdream when you install just enable the tbsci plugin then you can start to use it
Postby Plasma70 » Sat Apr 03, 2021 11:22 pm
where can i find this tbsci plugin?
Plasma70
Postby steven » Wed Apr 07, 2021 9:12 am
when you install our download DVBDream or TBSViewer it will auto install the CI plugin
Return to USB DVB-T2/T/C CI TV Box TBS5880/5881
