PCI-E 2.0, PCI-E 3.0?
Postby garry » Wed Oct 15, 2014 6:50 pm
Do you plan to support PCI-E 2.0 and 3.0 interfaces? if so, when approximately?
The problem is that new servers do not support PCI-E 1.0 so in new server platforms it is impossible to use your tuners...
garry
Re: PCI-E 2.0, PCI-E 3.0?
Postby updatelee » Wed Oct 15, 2014 8:07 pm
They should... The PCI spec should always be backward compatible.
Postby garry » Wed Oct 15, 2014 8:24 pm
updatelee Wrote:The PCI spec should always be backward compatible.
Only in theory, but not in practice. Here is my post about it and the solution - http://www.tbsdtv.com/forum/viewtopic.php?f=36&t=8046
garry
Postby updatelee » Wed Oct 15, 2014 9:17 pm
The saa7160 used in many tbs cards only support pcie 1.0 so only option is to move to another interface ic.
Postby crazycat » Thu Oct 16, 2014 12:37 am
garry Wrote:Do you plan to support PCI-E 2.0 and 3.0 interfaces? if so, when approximately?
Problem often in BIOS (initial device detection). But possible hardware solution like implemented in 6983 - pericom pci-e switch (pcie 2.0 compatibled) + saa7160 media-bridge.
