Trouble with high speed transponders. SR28000-30000(Solved)
Postby Kompik » Fri Jan 18, 2013 5:24 pm
I have 6991, on transponder with symbol rate less than 28000 everything OK.
But if i tune to transponders with symbol rate more than 28000 i have a lot of error.
I use last drivers 121021 on my debian 2.6.32-5-686
I tune to Intelsat 15 85°:
11960H, 28800, DVB-S2, PSK8
warning: transport_error_indicator on pid 4102 (..., sid 0)
warning: transport_error_indicator on pid 2375 (..., sid 0)
warning: transport_error_indicator on pid 8131 (..., sid 0)
warning: too many transport errors, tuning again
debug: Frontend "TurboSight TBS 6991 DVBS/S2 frontend" type "QPSK (DVB-S/S2)" supports:
debug:  frequency min: 950000, max: 2150000, stepsize: 1011, tolerance: 5000
debug:  symbolrate min: 1000000, max: 45000000, tolerance: 0
debug:  capabilities:
debug:   INVERSION_AUTO
debug:   FEC_1_2
debug:   FEC_2_3
debug:   FEC_3_4
debug:   FEC_4_5
debug:   FEC_5_6
debug:   FEC_6_7
debug:   FEC_7_8
debug:   FEC_AUTO
debug:   QPSK
debug:   2G_MODULATION
debug:   FE_CAN_RECOVER
debug: frequency 11960000 is in Ku-band (higher)
^Cdebug: configuring LNB to v=18 p=1 satnum=0 uncommitted=0
debug: tuning QPSK frontend to f=11960000 srate=28800000 inversion=-1 fec=999 rolloff=35 modulation=psk_8 pilot=-1
warning: transport_error_indicator on pid 806 (..., sid 0)
warning: transport_error_indicator on pid 3002 (..., sid 0)
warning: TS discontinuity on pid 3570 expected_cc 12 got  0 (..., sid 0)
warning: transport_error_indicator on pid 3570 (..., sid 0)
warning: transport_error_indicator on pid 1760 (..., sid 0)
warning: TS discontinuity on pid 1901 expected_cc 15 got  9 (..., sid 0)
warning: transport_error_indicator on pid 1901 (..., sid 0)
warning: TS discontinuity on pid 1910 expected_cc  1 got  7 (..., sid 0)
warning: transport_error_indicator on pid 1795 (..., sid 0)
warning: TS discontinuity on pid 1391 expected_cc  0 got  8 (..., sid 0)
warning: transport_error_indicator on pid 1391 (..., sid 0)
warning: transport_error_indicator on pid 622 (..., sid 0)
warning: transport_error_indicator on pid 1814 (..., sid 0)
warning: transport_error_indicator on pid 7287 (..., sid 0)
warning: transport_error_indicator on pid 2360 (..., sid 0)
warning: transport_error_indicator on pid 1526 (..., sid 0)
warning: transport_error_indicator on pid 2399 (..., sid 0)
warning: TS discontinuity on pid 6972 expected_cc 15 got  0 (..., sid 0)
warning: transport_error_indicator on pid 6972 (..., sid 0)
warning: transport_error_indicator on pid 8088 (..., sid 0)
warning: transport_error_indicator on pid 4582 (..., sid 0)
warning: transport_error_indicator on pid 5573 (..., sid 0)
warning: transport_error_indicator on pid 4281 (..., sid 0)
warning: transport_error_indicator on pid 4948 (..., sid 0)
warning: transport_error_indicator on pid 6565 (..., sid 0)
warning: transport_error_indicator on pid 7720 (..., sid 0)
warning: transport_error_indicator on pid 4057 (..., sid 0)
warning: transport_error_indicator on pid 5493 (..., sid 0)
warning: transport_error_indicator on pid 5502 (..., sid 0)
warning: transport_error_indicator on pid 2065 (..., sid 0)
warning: transport_error_indicator on pid 7941 (..., sid 0)
warning: transport_error_indicator on pid 6943 (..., sid 0)
warning: transport_error_indicator on pid 988 (..., sid 0)
warning: transport_error_indicator on pid 1904 (..., sid 0)
warning: TS discontinuity on pid 1901 expected_cc 10 got  0 (..., sid 0)
warning: TS discontinuity on pid 1941 expected_cc 14 got  6 (..., sid 0)
warning: transport_error_indicator on pid 1941 (..., sid 0)
warning: transport_error_indicator on pid 3328 (..., sid 0)
warning: TS discontinuity on pid 2200 expected_cc  6 got 11 (..., sid 0)
warning: transport_error_indicator on pid 2200 (..., sid 0)
warning: TS discontinuity on pid 5661 expected_cc 12 got 14 (..., sid 0)
warning: transport_error_indicator on pid 5661 (..., sid 0)
warning: TS discontinuity on pid 7080 expected_cc 10 got  3 (..., sid 0)
warning: transport_error_indicator on pid 7080 (..., sid 0)
warning: transport_error_indicator on pid 6379 (..., sid 0)
warning: transport_error_indicator on pid 531 (..., sid 0)
At slower transponders everything OK. transport_error_indicator on pid 3570 (
Kompik
Re: Trouble with high speed transponders. SR 28000-30000
Postby cody » Tue Jan 22, 2013 5:20 am
please, try this test driver:
http://www.basicupload.com/t9br0ve05cgm
and report back your results. if it doesn't help it could be your motherboard can't handle such data-rate and the solution then would be to optimize transfer buffers in the driver to compensate for your motherboard performance issues.
Postby Kompik » Tue Jan 22, 2013 4:52 pm
I found the cause of the problem!
I have one system with six of TBS6991.
Cable from Satellite dish connected to 4way splitter.
Second card (/dvb/adapter3) tune to Intelsat 15 85° 12080 H 26700 3/5 8PSK
Fourth card (/dvb/adapter7) tune to Intelsat 15 85° 11960 H 28800 3/5 8PSK
Both card connected to LNB via 4way splitter.
Problem was solved by taking away option "-v 18" in command string in dvblast of card7.
Old and test drivers work fine.
Sorry for the trouble
Kompik
