Multi transponder decrypting
Postby garry » Fri Dec 14, 2012 10:42 pm
Is multi transponder decrypting supported?
I.e. can I decrypt 2 tv channels simulteneuously from different transponders by one CAM module (with smartcard)? If these channels are from one transponder, CAM module with smartcard decrypts them well. But if channels are from different transponders?
garry
Re: Multi transponder decrypting
Postby steven » Sat Dec 15, 2012 3:25 pm
Hi garry
our hardware can not do this.but maybe you can use some soft like OSCAM maybe it can work like you say. :)
When channels are from different transponders?Because TBS6991 have two tuner so the max transponders can be deciphering
are two.
