Place tuner in 1U server?
Postby garry » Tue Aug 28, 2012 3:02 am
Is it possible to place TBS6991 in 1U server? And also TBS6984?
Thanks.
garry
Re: Place tuner in 1U server?
Postby updatelee » Tue Aug 28, 2012 8:12 am
well it would depend on the server I guess wouldnt it.
Postby steven » Thu Aug 30, 2012 5:06 pm
It is like "updatelee" said that it depend on the server, maybe it can only inserted by lie down
our card. if you can inserted like this,maybe you can use it . :)
Kind regards
Postby garry » Tue Sep 11, 2012 1:57 am
Ok, thanks for answer.
garry
Postby joshi » Thu Oct 10, 2013 3:40 pm
We use them in 1RU servers, but there is a little mechanical problem - lower F-connector is situated too low and you will have to saw off couple of millimeters from your server enclosure.
joshi
Postby joshi » Thu Oct 10, 2013 3:45 pm
One more thing - on some servers (mainly HP) you should switch PCIe to x1 mode and ensure, that proper voltage is supplied, either from PCEe settings, or by connecting ATX power directly to TBS card.
joshi
