TBS6991 On Ubuntu 18.04.
Postby BlueSkyThinking » Tue Nov 13, 2018 2:45 am
I think my tbs6991 has come to the end of its journey. Fantastic card, has served me well.
Was trying to compile the last drivers available (170330) and ran into this series of errors and warnings which resulted in the build process being stopped:
[code]\  CC [M]  /home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.o
/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.c: In function 'video_init':
/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.c:1307:2: error: implicit declaration of function 'init_timer'; did you mean 'init_timers'? [-Werror=implicit-function-declaration]
  init_timer(&vv->video_q.timeout);
  init_timers
/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.c:1308:31: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
  vv->video_q.timeout.function = saa7146_buffer_timeout;
/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.c:1309:21: error: 'struct timer_list' has no member named 'data'
  vv->video_q.timeout.data     = (unsigned long)(&vv->video_q);
scripts/Makefile.build:332: recipe for target '/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.o' failed
make[3]: *** [/home/rpq/tbs6991/linux-tbs-drivers/v4l/saa7146_video.o] Error 1
Makefile:1551: recipe for target '_module_/home/rpq/tbs6991/linux-tbs-drivers/v4l' failed
make[2]: *** [_module_/home/rpq/tbs6991/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.15.0-38-generic'
make[1]: Leaving directory '/home/rpq/tbs6991/linux-tbs-drivers/v4l'
make: *** [all] Error 2[/code]
On your forum pages I have seen this being reported, and the comment was around the new kernel 4.15 being used..
Admittedly that was against a different card TBS6285 the issue was posted on Sun Apr 15, 2018 4:45 am.
I need to move to 18.04 to stay current, and I need diseqc rotor and CI CAM.
Any body got any other suggestion, then to replace the card?
And what would its best and logical replacement be?
BlueSkyThinking
Re: TBS6991 On Ubuntu 18.04.
Postby steven » Tue Nov 13, 2018 10:52 am
Sorry that for 170330 driver only support kernel upto 4.10 for the new kernel it do not support now
Postby BlueSkyThinking » Thu Nov 15, 2018 3:22 am
Steven thanks, What a shame.
Which replacement card could then take the TBS6991 place. As I said I use a rotor and a CAM, so it needs to behave equal to or better than the TBS6991?
BlueSkyThinking
Postby steven » Fri Nov 30, 2018 11:18 am
Sorry about this , you can have a look at TBS6590 which support latest open source kernel
Postby BlueSkyThinking » Mon Dec 03, 2018 7:25 pm
Steven,
Thanks. Had a look at that card. does not mention diseqc. Is it capable of driving a dish rotor? Similar to tbs 6991.
Read the review from Satelescu on the card, impressive.
The question I have is that it mentions there seems to be a "ChangeModeTool utility".
Looking in the download section that seems to be a windows oriented piece of SW, how is this done under linux?
Thanks for assisting in clearing these last questions.
BlueSkyThinking
Postby steven » Tue Dec 04, 2018 9:21 am
Diseqc is no problem do not need worry about this .
For linux more professional, do not need tools as the software already added support more detail information
please have a look at this guide :
http://www.tbsiptv.com/download/tbs6590 ... _guide.pdf
it will tell you how to use with different mode in linux
any more question please feel free to ask us .
