simplest way to configure tuner on headless server
Postby Andyldex » Tue Sep 12, 2017 11:31 pm
Hi all,
I'm trying to use a TBS 6991SE under Linux on a headless server. The youtube video posted else where on this forum; https://youtu.be/VwXngRE89a4 seems to me to require a multicast network to work. Am I mistaken? Or if not is there a simpler way to get a stream to work without a Multicast network? My objective is to be able to test channel reception on a headless server and do visual quality test on a remote desktop. Is there a simple way to achieve this? If anyone has already done something similar it would be great to hear your experiences., hanks for any comments and advise,
Andy.
Andyldex
Re: simplest way to configure tuner on headless server
Postby steven » Sat Sep 30, 2017 2:31 pm
You can try tvheadend it is unicast http, more detail information you can use this user guide :
https://www.tbsiptv.com/download/tbs691 ... _guide.pdf
as both card is the same use way
