No signal on tuner B (Solved)
Postby helmut » Mon Jun 04, 2012 5:40 pm
As noted before, it appears there is no separate section for TBS 6991 which I have just bought.
For the TBS 6991: I have connected one lnb to tuner A and another lnb to tuner B. Windows Media Center says "No TV Signal Present" on Tuner B while Tuner A works fine. I have the same problem with DVB Dream and TBSViewer.
The lnb on tuner B is properly connected (I receive the satellite signal if I connect it to Tuner A).
Anything I must change to the setup - or does this indicate tuner B on the card is faulty?
Thanks.
helmut
Re: No signal on tuner B
Postby steven » Wed Jun 06, 2012 10:08 am
Hi helmut
When you are free,Can we connect to your PC to have a remote check?
if it is ok,You can send your detail message to our support@tbsdtv.com
Like Remote IP and password, or TeamViewer ID and Password,both is ok.
Postby steven » Tue Jun 12, 2012 2:23 pm
Hi All
This problem can be solved by update driver to V1.0.0.4
here is the linker:
http://www.tbsdtv.com/download/document/tbs6991/tbs6991-windows-driver_v1.0.0.4.zip
