6284 dvb c
6284 dvb c
Postby llololloy » Tue Aug 01, 2017 3:37 am
I have been using this card as a quad dvb-t2 tuner for a few years without issue.
I now need to use it as dvb-c in the same system (windows 7 pro)
I downloaded the latest drivers for t/t2/c and the card is recognised as 4 dvb-c tuners in windows but it will not receive any dvb-c signals.
I uninstalled and reinstalled the drivers without success and have rebooted multiple times.
I know there should be signal as I also have usb dvb-c tuners that work and I used the same cables etc...
Does anyone have any recommendations?
I really want to ditch the usb tuners and stick to my pci-e card.
Thanks.
llololloy
Re: 6284 dvb c
Postby steven » Tue Aug 01, 2017 4:07 pm
What about your DVB-C symbol rate ?
Re: 6284 dvb c
Postby llololloy » Wed Aug 02, 2017 2:51 am
Hi.
I used the same software and cables on the 6284 that I used on the usb tuners, but it picks up nothing.
I was scanning frequency 531000 with a 6952 symbol rate.
Works fine with the usb tuners.
llololloy
