Firmware not responding
Postby vts » Wed Jun 08, 2011 12:25 am
i've bought a second 6920 month ago. After some hours (maybe a day) working correct the firmware upload failes with following messages (there is also a qbox2 plugged in)
[148457.465540] cx24116_readreg: reg=0x1f (error=-5)
[148457.478476] cx24116_readreg: reg=0x1f (error=-5)
[148457.491495] cx24116_readreg: reg=0x1f (error=-5)
[148457.504518] cx24116_readreg: reg=0x1f (error=-5)
[148457.517501] cx24116_readreg: reg=0x1f (error=-5)
[148457.528274] cx24116_cmd_execute() Firmware not responding
[148520.889708] cx23885 0000:01:00.0: PCI INT A disabled
[148679.518283] cx23885 driver version 0.0.2 loaded
[148679.518324] cx23885 0000:01:00.0: enabling device (0000 -> 0002)
[148679.518336] cx23885 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[148679.520352] CORE cx23885[0]: subsystem: 6920:8888, board: TurboSight TBS 6920 [card=14,autodetected]
[148680.228097] tveeprom 2-0050: Huh, no eeprom present (err=-5)?
[148680.228099] cx23885_dvb_register() allocating 1 frontend(s)
[148680.228102] cx23885[0]: cx23885 based dvb card
[148680.230304] cx24116_readreg: reg=0xff (error=-5)
[148680.232428] cx24116_readreg: reg=0xfe (error=-5)
[148680.232430] Invalid probe, probably not a CX24116 device
[148680.232486] cx23885[0]: frontend initialization failed
[148680.232487] cx23885_dvb_register() dvb_register failed err = -1
[148680.232489] cx23885_dev_setup() Failed to register dvb adapters on VID_B
[148680.232492] cx23885_dev_checkrevision() New hardware revision found 0x0
[148680.232493] cx23885_dev_checkrevision() Hardware revision unknown 0x0
[148680.232498] cx23885[0]/0: found at 0000:01:00.0, rev: 2, irq: 16, latency: 0, mmio: 0xfb600000
[148680.232505] cx23885 0000:01:00.0: setting latency timer to 64
[148680.232508] IRQ 16/cx23885[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[148715.275522] tbsqboxs2: tbsqboxs2_set_voltage 0
[148717.694824] tbsqboxs2: tbsqboxs2_set_voltage 0
i've tried the card in 3 different motherboards on gentoo, ubuntu and windows always with the same failure.
Then i've wrote a mail to the vendor where i've bought the card that the card is defect. They told me that its within the 6 month guarantee and i should send them the defect card for replacement. Then they returned the card unrepaired/replaced because they did an insert test - booted the machine - and everything worked <-- But the error is only after a few hours!
So what can i do that the card work as expected?
vts
Re: Firmware not responding
Postby vts » Tue Jun 28, 2011 12:12 am
Have not seen cody for a long time ... are you still alive?
vts
