enigma2 drivers
enigma2 drivers
Postby jerrino77 » Mon May 18, 2015 5:54 pm
Hello all, I would ask if there is any chance to get TBS 5925 works with enigma2 receivers, at least with more powerful Mipsel devices such as Vu+ duo2 or Gigablue Quad Plus. Thanks
jerrino77
Re: enigma2 drivers
Postby crazycat » Tue May 19, 2015 2:32 am
Ask VU image-makers :) Full driver source is available.
Re: enigma2 drivers
Postby jerrino77 » Tue May 19, 2015 3:00 pm
Wow, really? I've read somewhere that driver was closed source, or at least a part of it! Well I already have all the tools for make images, so I will try to. If I need help may I ask something here?
jerrino77
Re: enigma2 drivers
Postby crazycat » Wed May 20, 2015 3:03 am
This stb6100/stv090x-based card, so all drivers is open. In original TBS V4L drivers "hidden" LNB power control code, but was quikly "open-sourced" (because used same cmd like 5980, 5920).
Re: enigma2 drivers
Postby elbandido » Sun Feb 21, 2016 8:42 am
Success with OpenPLi!
TBS5925 support has been added to a test image based on OpenPLi that I have installed on a Vu+ Duo2 receiver. The TBS5925 is a wonderful addition to the Duo2 enigma2 receiver, and I now have the 16APSK and 32APSK modulations.
Are there any ideas as to how I might add blindscan or is there a command line in telnet that would make the 5925 blindscan? I Would appreciate any ideas or suggestions that would make the 5925 blindscan using enigma2 image.
elbandido
