application
application
Postby EnoSat » Sun Nov 13, 2011 9:20 am
In some application bug with freq:
AltDVB - 10700~11538 work ok , 11568~11700 not work , 11700~12750 not work
TransEdit - 10700~11700 work ok , 11700~12750 not work
but in:
TBSViewer - 10700~11700 work ok , 11700~12750 work ok
EnoSat
Re: application
Postby Peon » Sun Nov 13, 2011 11:33 pm
Win XP SP3 :
Alt DVB version 2.2.0 Build 3912 work OK no defects
DVB Dream 1.6 work OK
TBS blind scan OK SR from 1000 - 45000, SR not found 200-1000 :oops:
CrazyScan not supported yet :(
Satfinder 2.7.0 work OK
TS Reader not supported yet :(
Peon
Re: application
Postby EnoSat » Mon Nov 14, 2011 2:48 am
on my WinXP SP3 work now correct only with Dev_Bda2Driver.int 0.2.1.764 in AltDVB
CrazyScan ok with streamreader.dll 1.0.7.775 and tbs5925.sys 1.0.0.6 (with 1.0.0.5 show not support)
EnoSat
Re: application
Postby Peon » Tue Nov 15, 2011 12:45 am
TBS5925.With the new driver V 1.0.0.7, does not work any software :( I returned 1.0.0.5. :x
Peon
Re: application
Postby EnoSat » Tue Nov 15, 2011 3:51 am
1.0.0.7 - TBS viewer - freeze , TransEdit - freeze
1.0.0.6 - TBS viewer ok , TransEdit - not work high band , DVB viewer - not work high band
EnoSat
Re: application
Postby bob » Fri Nov 18, 2011 4:46 pm
Please download the latest version 1.0.0.8,http://www.tbsdtv.com/download/TBS5925/TBS5925Driver_V1.0.0.8.zip
it should solve the freeze problem,and even the low symbol rate can't lock problem.
bob
Re: application
Postby Cjcr » Fri Nov 18, 2011 5:05 pm
bob Wrote:Please download the latest version 1.0.0.8,http://www.tbsdtv.com/download/TBS5925/TBS5925Driver_V1.0.0.8.zip
And what happens with LNB Power Off? seems don't work in tbs5925. (Tested with voltimeter)
Cjcr
Re: application
Postby EnoSat » Sat Nov 19, 2011 2:54 am
still not work high band in other aplication , etc. TransEdit , DVB Viewer
TBS Viewer ok - low and high band
EnoSat
Re: application
Postby steven » Mon Nov 21, 2011 11:53 am
Hi EnoSat
Would you mind give us your TransEdit's LNB setting picture(input value),we will have a test with your setting.
Re: application
Postby Peon » Mon Nov 21, 2011 3:03 pm
Hi EnoSat
Hi Steven. All my software works OK. EnoSat has a problem in the PC. It is only necessary to solve the low SR 200 - 1000. BlindScan and found a problem with manual lock. Thanks
Peon
