Blind scan SR below 1000
Postby Peon » Wed Nov 09, 2011 6:12 pm
Super soft, but has a problem with TP with SR lower than 1000.With TBS5925 not found: 23,5E 12660, SR 477, 12661 SR 555, 15,8E 11069 SR 333,11070 SR 795 and other. It also has some other flaws. I hope that will be rectified in the next version. :roll:
Peon
Re: Blind scan SR below 1000
Postby bob » Sat Nov 26, 2011 1:20 pm
the latest version 1.0.0.8 driver should be support low SR lock, Please check EnoSat's screenshots : http://enosat.euweb.cz/testlowsr.html
Regards!
bob
Postby Peon » Sat Nov 26, 2011 3:20 pm
Hi Bob.
Manually entering all the parameters work all drivers except 1.0.0.7. It is dysfunctional. But with BlindScan find anything under SR 1000, with any previously issued driver.
Peon
Postby crazycat » Sun Dec 25, 2011 7:07 am
STV090x BlindScan algo often can't find this ultra-low transponders. And for cold lock SR<1000 unreliable, official supported SR 1000-45000.
Postby Peon » Sun Dec 25, 2011 3:41 pm
crazycat Wrote:STV090x BlindScan algo often can't find this ultra-low transponders. And for cold lock SR<1000 unreliable, official supported SR 1000-45000.
There is a PC card or USB that can do this? BlindScan under low SR 1000, Thanks
Peon
