6928 and 11411 HB problem
Postby kafel » Thu Jan 02, 2014 5:14 am
Hi!
I bought tbs 6928, and averything is ok, but there's a problem with 11411 tp from hotbird 13.
tp 11: DVB-S2 8PSK SR 27500 FEC 5/6
http://www.lyngsat.com/packages/ncplus.html
I have Aston Cam 2,26, that working on this sat instalation in tv samsung UE46D7000 without any problem for two years, but not in ci in dvb-s slots on 11411, others transporder are ok.
6928 and 5980 works very good with acamd plugin & phoenix, but in supported CI this transporder is not working - in dvbviewer are many discontinuities, and apllication hangs.
I used tbs-cidll_v1.0.1.0, tbs-cidll_v1.0.1.2 and tbs-cidll_v1.0.1.3.
There's a known problem in Poland with this transporder, because here is a lot of HD positions with 5/6 correction only, and lot of tuners doesn't recognize it good, but why this CAM works very good with TV /this is the best for seca in Poland/, or why this dvb cards works without any problems with phoenix and acamd?
thanks for your suggestions.
kafel
Re: 6928 and 11411 HB problem
Postby kafel » Fri Jan 22, 2016 4:08 pm
solved with TbsCIapi 1.0.15
kafel
