DiseqC problem
DiseqC problem
Postby PetrMan » Sun Apr 28, 2013 8:04 pm
Hi, I have a new TBS6928. I have installed last drivers (W7 32 bit, MB Gigabyte 78MA) from TBS site and last DVBDream and TBSviewer. I have duo LNB (Astra 19.2 and 23.5) but I can tune 19.2 only (1000 channels and more).
With inserted CAM red diode is on. Is it OK? CAM menu in DVBDream and TBSviewer works fine but I can´t try it because my card is for Skylink (23.5).
There was three plug cable in the box with TV card without note at manual. This cable I didn´t switch on. Any idea? Thanks. Petr.
PetrMan
Re: DiseqC problem
Postby Retiree » Sun Apr 28, 2013 11:42 pm
I guess that, by analogy with TBS6680, red LED indicates the inserted CAM only.
The three plug cable to serve as additional power for some other cards (packer probably don't know)
Ostatně soudím, že ani celý vývojový tým...
Retiree
