Solution for Mediaportal Sleep problem
Postby steven » Fri Aug 24, 2012 2:02 pm
Hi All
Some users have reported that after suspend the mediaportal server config says
no card available, but with other DVB software it is ok, such as media center.
Two ways to solve it:
1st:
Please read this topic:
http://wiki.team-mediaportal.com/1_MEDI ... _detection
This is because MediaPortal TV Server only detects tuners on startup, not while it is running. So if the MediaPortal TV Server service starts before the driver/hardware is initialised by the OS, then the tuners will not be detected.
So you need to increase the delay time.
2nd:
Stop Windows adjusting the power level for PCI Express devices, switch the power saving off.
If you are experiencing such problem, just have a try with either solution.
Any problem or feedback are welcome to post here.
Re: Solution for Mediaportal Sleep problem
Postby atarian » Sat Mar 08, 2014 6:27 pm
I confirm I have the same problem as described above. Funny thing is I am observing this failure for more than 2 years, while my solution was to restart HTPC once every while in order to watch TV.
I have recently disabled PCI-e power saving in order to fix this (still not confirmed whether it works or not), but I believe it should be properly fixed in drivers. Inexperienced user will eventually become even more flustrated.
Thanks for taking careof that.
atarian
