Media Portal Cam support
Postby lukjod » Tue Dec 27, 2011 2:18 am
How can I use this card to watch encrypted channels in Media Portal
I put ci files from download drivers section of 6928 file TBS_CIdll_V1.0.0.8.zip but still can watch only FTA channels.
In dvb dream setup all is running fine (including my astoncrypt 2.19 cam with polish cyfra+ provider card) sd and hd channels.
Can You help me?
lukjod
Re: Media Portal Cam support
Postby steven » Wed Dec 28, 2011 2:56 pm
Hi lukjod
We are communicate with Media Portal about this problem now,and have some progress,Later maybe you \
can use TBS6928 CI with Media protal.
Re: Media Portal Cam support(Can support now)
Postby steven » Sun Apr 15, 2012 8:13 pm
Hi All
Media Portal can support all of our CI device now. :D
Postby herrbasan » Wed May 30, 2012 6:55 pm
It's important to note that MediaPortal doesn't support the TBS CI right "out of the box". You need to patch a few files to make it work.
But i can report that it works flawlessly with MP 1.2.2 (it should work with 1.2.3 too).
Here is the link:
http://forum.team-mediaportal.com/threa ... ts.103276/
TBS 6928 / Unicam Deltracrypt CAM / Sky Germany V13 Card
Windows 7 x64 / MediaPortal 1.2.3
herrbasan
