Tested CAMs which work with TBS 6928
Postby warumnix » Wed Nov 02, 2011 2:40 pm
Hi All,
the same CAMs as listed here http://www.tbsdtv.com/forum/viewtopic.php?f=33&t=1420 also have been tested, and they work fine with the TBS 6928, if you've tested more another CAMs, welcome to post the result here, thanks.
warumnix
Re: Tested CAMs which work with TBS 6928
Postby ncarlson » Fri Nov 04, 2011 1:16 am
Thanks warumnix. I'm pretty new at this, but I suppose since the diablo is on there that the Jolly CAM 1.01is supported too? Because I have been trying to get it to work, but it is on and off...running windows seven, and DVB Viewer Pro 4.9.0.0...
ncarlson
Postby steven » Wed Dec 28, 2011 2:57 pm
Hi ncarlson
yes,of course. it should be ok. :D
Postby Olli1984 » Wed Mar 07, 2012 2:36 pm
I have a Unicam module, Rev. 2
Are there any experiences with this CAM?
I get in scrambled channels no picture and no sound.
Olli1984
Postby bob » Fri Apr 13, 2012 7:05 pm
could you provide more detial about your situation? Which player you used? What CA card?
If you use it in windows,please try MCE tool to read the MMI menu,if it can read it,than 6928 could support your CAM.
And it will be other reason why it can't descramble the TV channel.
bob
Postby herrbasan » Wed May 30, 2012 7:01 pm
I've tested the Unicam Deltacrypt CAM with a Sky Germany V13 card with following software:
MediaPortal - Works
Windows Media Centre - Works
DVBLink - didn't work for me
DVBViewer - Works
DVBViewer Recoding Servive (works, with a tiny bug that is allready reported and is in progress of fixing)
All in all, in my experience the TBS CAM support is really really good. No artifacts, pretty fast response, and very reliable.
TBS 6928 / Unicam Deltracrypt CAM / Sky Germany V13 Card
Windows 7 x64 / MediaPortal 1.2.3
herrbasan
Postby Blaster » Thu Jun 21, 2012 9:58 pm
I have also the Unicam 2 Deltacrypt CI Modul Hardware Rev. 2.0(FW Sparta 5.34) with a HD+Card and use DVBViewer Pro(4.9.6.20). But it doesn't work, any suggestions?
tahnks for help!
support.zip
(43.86 KiB) Downloaded 379 times
Blaster
