TBS6280 install the driver on Linux Ubuntu 14.04 LTS x64
Postby xunil2003 » Tue Apr 07, 2015 7:31 am
I am French forgive me if I speak little English.
I can not install the driver for my card on my 6280 BTS distribution Ubuntu 14.04 LTS x64.
My core is
laurent@Laurent-Bureau:~/pilotes/tbs-linux-drivers_v150109/linux-tbs-drivers$ uname -a
Linux Laurent-Bureau 3.13.0-44-generic #73-Ubuntu SMP Tue Dec 16 00:22:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
That's how I made the driver installation
sudo ./v4l/tbs-x86_64.sh
sudo make
sudo make install
sudo reboot
There was no error during installation
Back orders for driver installation
http://code.empreintesduweb.com/8908.html
http://textup.fr/123525JQ
After the installation of the completed pilot I reboot the computer and I check if the driver is installed
laurent@Laurent-Bureau:~/pilotes/tbs-linux-drivers_v150313/linux-tbs-drivers$ dmesg | grep frontend
[   49.711430] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[   49.711431] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[   49.711438] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[   49.711439] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[   49.711443] saa716x_core: disagrees about version of symbol dvb_register_frontend
[   49.711445] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[   49.711625] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[   49.711626] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[   49.711632] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[   49.711633] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[   49.711637] saa716x_core: disagrees about version of symbol dvb_register_frontend
[   49.711638] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
How to install the driver on ubuntu 14.04 x64 ?
Thank you.
xunil2003
Re: TBS6280 install the driver on Linux Ubuntu 14.04 LTS x64
Postby crazycat » Wed Apr 08, 2015 5:56 am
remove kernel media driver before install tbs-linux-drivers:
sudo rm -r -f /lib/modules/$(uname -r)/kernel/drivers/media
Postby xunil2003 » Wed Apr 08, 2015 7:28 am
Thank you it works flawless.
I did this:
sudo mv /lib/modules/$(uname -r)/kernel/drivers/media /home/$USER/media.bak
sudo make && sudo make install
I preferred to save media
instead of deleting media directly
After running I can delete it
sudo rm -r -f /home/$USER/media.bak
Checking I see all my pci cards
[   50.618278] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[   50.706460] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[   52.547280] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   52.636979] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   54.172394] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   54.258385] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
Thank you.
xunil2003
