tbs62x0fe: attach failed
Postby Muzer » Fri Oct 25, 2013 11:12 pm
I'm running Gentoo with kernel 3.10.7.
I've installed the drivers, but on startup, there appear to be errors loading the module:
muzer@muzer-gentoo ~ $ dmesg | grep -A 5 -B 5 -i tbs
[    3.835155] Write protecting the kernel text: 6344k
[    3.835295] Write protecting the kernel read-only data: 2492k
[    4.909046] cat (1152) used greatest stack depth: 6284 bytes left
[    5.064731] init-early.sh (1151) used greatest stack depth: 5912 bytes left
[    7.047547] systemd-udevd[1265]: starting version 204
[    8.233840] tbs6991se: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[    8.233844] Disabling lock debugging due to kernel taint
[    8.335548] snd_hda_intel 0000:00:1b.0: irq 46 for MSI/MSI-X
[    8.381009] IR keymap rc-tbs-nec not found
[    8.381011] Registered IR keymap rc-empty
[    8.381059] input: saa716x IR (TurboSight TBS 6280) as /devices/pci0000:00/0000:00:1c.4/0000:02:00.0/rc/rc0/input6
[    8.390011] input: failed to attach handler kbd to device input6, error: -172900352
[    8.390080] rc0: saa716x IR (TurboSight TBS 6280) as /devices/pci0000:00/0000:00:1c.4/0000:02:00.0/rc/rc0
[    8.390083] DVB: registering new adapter (SAA716x dvb adapter)
[    8.496126] systemd-udevd[1291]: renamed network interface eth0 to net0
[    9.094378] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    9.094490] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    9.094539] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    9.094592] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    9.094643] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    9.094894] hda_intel: Disabling MSI
[    9.295089] tbs62x0fe: attach failed
[    9.295094] TurboSight TBS 6280: frontend initialization failed
[    9.295151] DVB: registering new adapter (SAA716x dvb adapter)
[    9.306436] tbs62x0fe: attach failed
[    9.306441] TurboSight TBS 6280: frontend initialization failed
[    9.370011] hda_codec: cannot build controls for #1 (error -16)
[    9.373017] hda_codec: cannot build controls for #2 (error -16)
[    9.376017] hda_codec: cannot build controls for #3 (error -16)
[    9.376105] input: HDA NVidia HDMI as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[    9.398805] i801_smbus 0000:00:1f.3: SMBus using PCI Interrupt
Trying to actually use the device doesn't work - the frontend files in /dev/dvb/adapterN don't exist (though net, dvr and demux files do).
EDIT: Forgot to mention, using driver 130927
Muzer
Re: tbs62x0fe: attach failed
Postby Muzer » Fri Oct 25, 2013 11:45 pm
lspci -vvnn for the card
02:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
        Subsystem: Device [6280:0011]
        Latency: 0, Cache Line Size: 32 bytes
        Region 0: Memory at efd00000 (64-bit, non-prefetchable) [size=1M]
        Kernel modules: saa716x_tbs_dvb
My kernel config is attached (note that I've made a small change that has fixed the RC warning, but the main issue still remains)
config.gz
(24.91 KiB) Downloaded 774 times
Muzer
Postby cody » Fri Nov 01, 2013 6:45 pm
Hi, the error message "tbs62x0fe: attach failed" you get means hardware fault, i.e. defective card and that the driver cannot communicate and initialize the tuner on the board. so, it has nothing to do with some software problem in Linux. please, contact us on euro_support@tbsdtv.com and support@tbsdtv.com , because it needs to be replaced with new board under the warranty. also, include information from where you purchase it. thank you.
