TBS 6280 dual tuner used
Postby xunil2003 » Wed Oct 24, 2012 5:34 am
I'm French exuser me if I speak badly your language.
I'm running kubuntu 12.04 and I use Kaffeine to watch
I installed the TBS 6280.
Kaffeine just tells me that the device 3 is not connected .
I also has information for the TBS 6981 into my computer to the satellite.
In Kaffeine TV menu -> Configure Television :
In the Device tab 3:
he appears : Device not connected
In the Device tab 4 :
DVB-T
Tuned timeout: 1500
Source: autoscan
How to enable device 3 to use the dual tuner DVB-T2 ?
The device 4 found at TV channels
This card can watch and record two different channels from two different frequencies at the same time. how to use this function in linux ?
It also allows you to pause a live broadcast and continue from where you left with the Time-shifting function. how to use this function in linux ?
lspci
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
07:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
laurent@PC-ubuntu:~/laurent$ ls /dev/dvb
adapter0  adapter1  adapter2  adapter3
llaurent@PC-ubuntu:~/laurent$ lsmod | grep tbs
tbsfe                  13023  2
tbs6981fe              79739  2
tbs62x0fe              23069  2
rc_tbs_nec             12502  0
saa716x_tbs_dvb        48553  0
tbs6928fe              17785  1 saa716x_tbs_dvb
tbs6922fe              22311  1 saa716x_tbs_dvb
saa716x_core           50804  1 saa716x_tbs_dvb
rc_core                26884  12 ir_lirc_codec,ir_mce_kbd_decoder,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,ir_nec_decoder,rc_tbs_nec,saa716x_tbs_dvb,cx23885
dvb_core              109664  4 saa716x_tbs_dvb,saa716x_core,cx23885,videobuf_dvb
i2c_algo_bit           13423  1 saa716x_tbs_dvb
tbs6618fe              17791  1 saa716x_tbs_dvb
tbs6991fe              17785  1 saa716x_tbs_dvb
stv090x                62337  1 saa716x_tbs_dvb
tbs6680fe              17791  1 saa716x_tbs_dvb
tbs6982fe              22367  1 saa716x_tbs_dvb
laurent@PC-ubuntu:~/laurent$ dmesg | grep tbs
[   22.140077] tbs6982fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[   22.724861] Registered IR keymap rc-tbs-nec
[   24.580220] Registered IR keymap rc-tbs-nec
[  817.165824]  tbs6981fe - software version is 1.95.2.5
[  817.165826]  tbs6981fe - Successfully Initialized
What should he do?
Thank you.
xunil2003
