TBS6280 IR software V1.0.0.3
Postby Max67 » Mon Oct 10, 2011 9:06 pm
I don't seem to be able to get this to work under Mythbuntu 11.04. Any instructions or pointers from anyone who has successfully got their remote to work would be greatly appreciated.
Max67
Re: TBS6280 IR software V1.0.0.3
Postby steven » Sat Oct 15, 2011 11:38 am
Remote control for TBS 6280 is not supported yet in Linux - that
support is upcoming - probably it will be ready short after Linux
kernel 3.x became default kernel for many new Linux distributions -
starting with Ubuntu 11.10, which is going to be released October
13th, 2011. we decided not to spend time developing remote control
support for the new products until new remote control infrastructure
in the Linux kernel is not finished and widely accepted - in the last
several kernels the old 'ir_core' is replaced by the new 'rc_core'
remote control infrastructure. however, to our knowledge TBS are still
the only PCI-Express DVB-S2 cards with Linux support and working remote control
in Linux.
So please wait for our good news.
Postby delboy711 » Tue Oct 25, 2011 3:40 am
I am confused does the IR port on TBS6280 work with the 111017 drivers or not?
I am running it on Mageia 1 with a 2.6.38 kernel
dmesg
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
dib0700: loaded with support for 21 different device-types
usbcore: registered new interface driver dvb_usb_dib0700
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
lirc_dev: IR Remote Control driver registered, major 251
IR LIRC bridge handler initialized
but there is no /dev/input/device created
lsmod | grep ir
ir_lirc_codec          12898  0
lirc_dev               19166  1 ir_lirc_codec
ir_mce_kbd_decoder     12879  0
ir_sony_decoder        12549  0
ir_jvc_decoder         12546  0
ir_rc6_decoder         12546  0
ir_rc5_decoder         12546  0
ir_nec_decoder         12546  0
rc_core                26874  9 ir_lirc_codec,ir_mce_kbd_decoder,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,dvb_usb_dib0700,ir_rc5_decoder,dvb_usb,ir_nec_decoder
Which hardware module should be loaded? Are there any instructions available?
Any pointers will be welcome.
delboy711
Postby steven » Tue Oct 25, 2011 10:26 am
About the IR is not supported now,But it is ready to release soon.
