First HTPC build
First HTPC build
Postby rbel » Fri May 10, 2013 5:47 pm
I have been thinking of building an HTPC and browsing has indicated that the TBS 6280 tuner is probably the best dual T2 tuner available in PCIe form. Given the addition of some good quality supporting components and MCE, is the 6280 likely to provide the quality of signal and functionality of my existing 5 year old Panasonic HDD box?
rbel
Re: First HTPC build
Postby steven » Sun May 12, 2013 8:53 pm
Thanks for your consideration for our product,and from your description ,TBS6280 should meet your needs,
You can have a try. :)
