TBS6280 in a passively cooled case?
Postby omenatalo » Tue Mar 12, 2013 6:04 pm
I'm thinking about an HTPC build with the HDPLEX H5.S. This case is passively cooled and has no fans, but does have vent grills above and below the expansion slot where the TBS6280 would go.
On their website, HDPLEX show a build with tuner card with fan fitted underneath, but that seems to defeat the point of a passive case somewhat!
Does anyone here have experience of using this card in a passive case?
TBS staff, I have heard that tuner cards can get very hot. What would you recommend?
omenatalo
Re: TBS6280 in a passively cooled case?
Postby steven » Fri Mar 22, 2013 10:14 am
Hi omenatalo
Truly to say that TBS6280 is hot, but it is ok to use,If you can add a fan like the picture,
I am sure that it is ok to use.
