TBSVHID problem encountered with Windows 8 x64
Postby Kiwi » Fri Dec 28, 2012 1:24 pm
What is the error message there? How can I solve it?
Or should I proceed to WinLIRC?
TBS6285 is a bad card and TBS is a bad service company.
The CEO of TBS had better contact me to understand what happened.
Kiwi
Re: TBSVHID problem encountered with Windows 8 x64
Postby smile » Sat Dec 29, 2012 10:14 am
Hi Kiwi
The promble maybe is your system reason. you can search" windows 8 X64 The parameter is incorrect" in google. you will get many result.
http://social.technet.microsoft.com/For ... 49692dd78e
best wishes
smile
Postby Kiwi » Sat Dec 29, 2012 1:15 pm
smile Wrote:Hi Kiwi
best wishes
I see... but I just installed the TBSVHID setup executable file and still got that message. I do not know which file I should be replacing.
Anyway, I also used WinLIRC (no need to install) and it seems to work ok. Just that I seem to find response somewhat sluggish, like I need to press for about 1-2 seconds before it respond.
Kiwi
