Is this pixellation due to signal issue or otherwise?
Postby Kiwi » Thu Oct 25, 2012 3:53 pm
TBS6285 is a bad card and TBS is a bad service company.
The CEO of TBS had better contact me to understand what happened.
Kiwi
Re: Is this pixellation due to signal issue or otherwise?
Postby ArferDaley » Fri Oct 26, 2012 11:13 am
i get the same problem somedays worse than others i checked my signal it was good at the time of the recording
ArferDaley
Postby steven » Fri Oct 26, 2012 11:16 am
Hi Kiwi
What about the other transponder? is all like this ?and you can have a test with other video decoder too. :)
Postby Kiwi » Fri Oct 26, 2012 11:23 am
steven Wrote:Hi Kiwi
Sorry, but what is the meaning of transponder? Do u mean tuner?
Besides, I don't think the video decoder matters. I see the same pixellation whether I use KMPlayer, Media Player Classic, or VLC player.
Kiwi
Postby grapefruit » Mon Oct 29, 2012 9:32 am
Kiwi Wrote:Sorry, but what is the meaning of transponder? Do u mean tuner?
The artifact is part of your recorded file already, so it doesn't matter which player you use, you will still see the artifact.
Pixellation or artifact can happen due to packet loss, meaning that part of data is missing or has error.
grapefruit
Postby steven » Mon Oct 29, 2012 11:10 am
It is about the other frequency ?and it is that your signal is not very well.
Postby Kiwi » Mon Oct 29, 2012 3:26 pm
It is a DVB-C signal u know? This means that it's supposed to come through ground cables and be less affected by the aerial noise, isn't it?
Kiwi
Postby grapefruit » Tue Oct 30, 2012 12:07 pm
Kiwi Wrote:It is a DVB-C signal u know? This means that it's supposed to come through ground cables and be less affected by the aerial noise, isn't it?
Nothing is perfect.
A glitch in the signal might still happen occasionally. If you have too much of it and too often, then something might be wrong with your signal or for some other reason.
grapefruit
Postby Kiwi » Wed Oct 31, 2012 2:16 pm
Nothing is perfect.
I see... anyway, from what I observed, I seem to get such glitches when Tuner B is doing the recording and not Tuner A (I mean the logical devices Tuner A and B on this single tuner card). Will try to let Tuner A record stuff and observe further.
Kiwi
Postby steven » Thu Nov 29, 2012 4:20 pm
Hi Kiwi
Do you have fixed your problem ?
