TBS6280 incompatible with ASUS E45M1-I Deluxe
Postby Sotamarsu » Wed Aug 08, 2012 2:16 pm
I just got this ASUS E45M1-I Deluxe motherboard to my test bench and got it working nicely except one thing. The machine won't detect TBS6280 TV Tuner Card. The device won't come to device manager or isn't detected by Mythbuntu either. I have tried setting the BIOS with different settings, but there really isn't very much to adjust there.
If you have gotten this motherboard to detect this TV Tuner Card then I would like to hear how did you do it.
TV Tuner Card is working great because Dell Optiplex GX620 and ASUS P8Z77-V Deluxe don't have any problem with it.
Sotamarsu
Re: TBS6280 incompatible with ASUS E45M1-I Deluxe
Postby steven » Thu Aug 09, 2012 1:00 pm
Hi Sotamarsu
This problem is the PCI-E 1.0a compatible problem,need ASUS E45M1-I Deluxe to
update the BIOS to compatible PCI-E1.0a,So we need to contact ASUS to update
the BIOS to fix this problem.
