TBS6280 issues
TBS6280 issues
Postby davew » Fri Jun 15, 2012 6:36 am
I have just installed a TBS6280 dual tuner pcie card.
The remote control doesn't really work. I know that the remote is transmitting because the mute and numeric keys work.
PIP - seems to only be available for a few channels.
Pausing live TV - sort of works but if you try to skip forward you get a blank picture.
Anyone any ideas???
I am about to return the card as it doesn't seem to do what is says.
Dave
davew
Re: TBS6280 issues
Postby steven » Fri Jun 15, 2012 9:48 am
Hi davew
Which soft you want to use remote? We are full support WInLIRC which can control
a lot of program.
here is the information:
http://www.tbsdtv.com/forum/viewtopic.php?f=51&t=7682
Wish this can help you.
Re: TBS6280 issues
Postby davew » Wed Jun 27, 2012 5:11 am
I just wanted to use the remote control supplied with the card to control the card / TBS Viewer software.
Due to this and the other problems I have returned the card for a refund.
If it had fully worked and / or there was a way of obtaining sensible support for any problems I would have kept it!
Dave.
davew
Re: TBS6280 issues
Postby steven » Wed Jun 27, 2012 10:51 am
Hi davew
Do you have used TBSVHID which can control all the player you want?
