TBS6280 - HD channels and DVBDream 1.7b
Postby SquareEyes » Fri Apr 06, 2012 4:18 am
Recently bought TBS6280 and have been testing TBSViewer and also downloaded the DVBDream 1.7b from the downloads section here.
TBSViewer plays HD channels fine but when I try and do the same and select a HD channel in DVBDream 1.7b, it constantly loads a bar at the bottom right hand side next to the little speaker icon and the two bars are called H264 and AAC.
The H264 fills with red and then starts over and over again, and the AAC remains blank.
DVBDream does show the channel and program info and signal level and quality in the status bar.
Is there a way to get DVBDream working with TBS6280, or perhaps a way of opening two instances of TBSViewer as it is a dual tuner card? Has anyone managed to get HD channels working with DVBDream 1.7b or one of the 1.5 versions?
SquareEyes
Re: TBS6280 - HD channels and DVBDream 1.7b
Postby steven » Sat Apr 07, 2012 10:58 am
Hi SquareEyes
Would you mind seting the Vidoe and Audio code for DVBDream In Option->Video to set it.
This must be the decoder's problem.
