IR Remote Problems
IR Remote Problems
Postby Ozymandias » Fri Oct 21, 2011 7:01 am
I have recently bought a TBS6280. The installation went fine, I intend to use it with Windows 7 Windows Media Centre so I just downloaded the drivers from the internet and installed them and the card was recognised straight away.
The IR remote however does not show up in the HID section of device manager and it doesn't work in Windows Media Centre or VBSViewer.
I've tried reinstalling the driver after completely removing it and unplugging and plugging in the IR receiver. I've also tried reinstalling without a restart in the middle and with and no matter what I do the remote just won't show up.
Does anybody have any suggestions?
Ozymandias
Re: IR Remote Problems
Postby bob » Fri Nov 18, 2011 4:36 pm
Please download the IR software for TBS6280,here is the link: http://www.tbsdtv.com/download/common/S ... ID(1.0.0.3).zip
After install it,you can check the software manual,it will show you how to use it. Very easy to achieve.
bob
