TBS-6220 - Won't receive with good signal on Windows 10/11
Postby vma » Tue Aug 19, 2025 3:36 pm
I tried my TBS-6220 (after a long time) with two computers running Windows 10 and Windows 11.
Both show the same symptom: it is as if the signal was very bad. Image is blocky or no image at all. Most of the time even the service names are not correctly shown.
The same antenna cable works perfect with a TBS-5580.
Using CrazyScan2 the spectrum is rendered correctly and the constellation diagram works. But I get no picture using different apps (TSReader, VLC, etc.). With my own VMA Stream Reader, I have the same issue. Everything works fine with the TBS-5580.
Any idea what could be wrong?
Thanks,
Vitor
https://vma-broadcast.com/vma-video-analyser-package/
vma
Re: TBS-6220 - Won't receive with good signal on Windows 10/
Postby smile » Wed Aug 20, 2025 9:34 am
Hello
TBS6220 is too old,12years ago,It might be that some components have become outdated.
Best Regards
smile
Postby crazycat » Thu Aug 21, 2025 4:47 am
vma Wrote:Using CrazyScan2 the spectrum is rendered correctly and the constellation diagram works.
Show screenshoot from CS2. I have 6220 sample, will check later.
Postby DVB » Thu Aug 21, 2025 9:36 am
I had 6220 few years ago and I recall that it was easy to overload it with too strong signal. @vma if you're running from some modulator, this might be the source of your issue.
Easy to spot this - great constellation, but high BER. Decreasing RF Level helped.
If that's not the source, please provide screenshot from CrazyScan2 (RF & sample IQ) like crazycat said.
And now you're watching 8K:
KKKKKKKK
DVB
