tbs 6920 driver v1.0.5.0 22Khz problem
Postby satdude » Fri Aug 12, 2011 9:05 am
I have my C-band lnb connected to port A(0Khz) and Ku-band lnb connected to port B(22Khz). I installed the tbs 6920 driver v1.0.5.0 and my channels on C-band work but none of my channels on Ku-band work. I rolled back the driver to v1.0.4.1 and both my C-band and my Ku-band channels work.
satdude
Re: tbs 6920 driver v1.0.5.0 22Khz problem
Postby steven » Wed Aug 17, 2011 11:20 am
Thanks for your test report.we will check it later
Postby steven » Wed Aug 17, 2011 12:38 pm
would you mind try this driver to have a test
it is for xp-32 version
http://hotfile.com/dl/127038311/7b2593d ... r.rar.html
Postby satdude » Thu Aug 18, 2011 7:05 am
steven Wrote:Hi
I installed the driver and restarted my computer. This did not fix the problem. I am using Vista 32bit.
satdude
Postby steven » Fri Aug 19, 2011 2:08 pm
Would you mind tell me which player you are using,and give your LNB setting's picture,like you are use 22k to change LNB
