tbs 6920 bsod
tbs 6920 bsod
Postby Max1983 » Tue Aug 30, 2011 2:05 am
bsod in windows XP, 7.
With the old drivers in XP works longer just 7 times per hour.
With the new drivers, less than 1 minute.
And so the first day of purchase.
What to advise?
My system info.zip
Mini Dump and system info.
(11.73 KiB) Downloaded 400 times
Max1983
Re: tbs 6920 bsod
Postby steven » Wed Aug 31, 2011 11:55 am
Would you mind give us more information,which sat and TP you are use,and which view player you are use when bsod.
Re: tbs 6920 bsod
Postby Max1983 » Sat Sep 03, 2011 2:59 am
I did not understand English so may not understand your question.
I'm using the latest drivers posted in the website and use as a player for playback DVBViewer or TBSViewer.
Max1983
Re: tbs 6920 bsod
Postby Max1983 » Sat Sep 03, 2011 3:47 am
use ProgDVB 6 (6.70.6.0) also reboots the computer.
MainBoard M4A78LT-M LE (last version bios, no problems with System Works for labeled nebylo).
DDR3 Apacer 2 GB.
use Core Unlock processor means motherboard...
Max1983
Re: tbs 6920 bsod
Postby steven » Mon Sep 05, 2011 9:32 am
Hi Max1983
Would you mind try our OEM TBSView or DVBDream to have a test.
