move antenna, motor sg2100
Postby Alfredo » Tue Apr 15, 2014 5:25 am
Hello
Does anyone know how to move an antenna?
I have a SG2100 motor and I could not move it using: gotx or scan-s2.
Thank you,
Alfredo
Alfredo
Re: move antenna, motor sg2100
Postby SergioDanielG » Mon Apr 21, 2014 9:05 pm
Hi Alfredo.
I moved my motor using vdr, kaffeine, tune-s2, Mythtv and other apps.
Check this links for examples:
http://www.sergiodanielg.com.ar/2012/03 ... h-vdr.html
http://www.sergiodanielg.com.ar/2012/07 ... r-h-h.html
http://www.sergiodanielg.com.ar/2012/04 ... -para.html
Hope it's util.
Regards.
SergioDanielG
Postby Alfredo » Sat Apr 26, 2014 12:47 am
Thanks for you answer.
Kaffeine drives the motor, but anywhere. The other programs I never used.
Under command line, which other do you use?
I saw the links some time ago. I never found the installer for them.
The motor said: DiSEqC 1.2 and DiSEqC 1.3; and recommend use goto x
Under Windows work fine with DVBView
Thanks,
Alfredo
Alfredo
Postby SergioDanielG » Thu May 01, 2014 12:13 pm
You can try tune-s2 from command line, download from https://bitbucket.org/updatelee/tune-s2
It can move motor like usals and work with diseqc 1.2
Regards.
SergioDanielG
Postby Alfredo » Tue Jul 22, 2014 1:02 pm
Hi Sergio
Don't work for mi.
I use Kaffeine to move antena.
I use this formula to change position 2*(my position) - Satelite position
Example:
Antenna is 58W (my position); Satelite Hispasat 30W
2*58-30=86 --> I use this value to position in /home/user/.kde4/share/apps/kaffeine/scanfile.dvb and not 30W
Alfredo
