6922 vs 6921 ?
6922 vs 6921 ?
Postby eldon » Thu Jul 28, 2011 4:42 pm
I've been trying to understand the differences between those two cards but i can't seem to find any..
Being a linux user i see you mention the s2api driver for the new 6922, should we understand that its driver is different from the one provided with the 6921 ?
i'm planning on replacing my remaining pci cards with tbs pci-e ones but i'd like a quick comment on your part concerning the new 6922.
thx
eldon
Re: 6922 vs 6921 ?
Postby steven » Tue Aug 02, 2011 3:28 pm
The difference is the chip and bridge.
6922 are use SAA7160ET , and 6921 are use cx23885.
The tuner 6922 is good than 6921.
thanks
