failed setup driver
failed setup driver
Postby admsasha » Wed May 15, 2019 3:58 pm
# uname -a
Linux videoserver 4.9.155-nrj-desktop-1rosa-x86_64 #1 SMP PREEMPT Fri Feb 8 12:09:09 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
02:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
        Subsystem: Device [6221:0001]
        Interrupt: pin A routed to IRQ 11
        Region 0: Memory at dc500000 (64-bit, non-prefetchable) [size=1M]
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
        Kernel modules: saa716x_tbs_dvb
if install https://www.tbsiptv.com/download/common ... 170330.zip, then driver is successfully installed but not loaded.
# modprobe saa716x_tbs_dvb
modprobe: ERROR: could not insert 'saa716x_tbs_dvb': Invalid argument
#dmesg
[ 3666.343562] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[ 3666.343567] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[ 3666.343626] saa716x_core: disagrees about version of symbol dvb_register_adapter
[ 3666.343628] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[ 3666.343670] saa716x_core: disagrees about version of symbol dvb_dmx_release
[ 3666.343672] saa716x_core: Unknown symbol dvb_dmx_release (err -22)
[ 3666.343705] saa716x_core: disagrees about version of symbol dvb_net_init
[ 3666.343707] saa716x_core: Unknown symbol dvb_net_init (err -22)
[ 3666.343737] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[ 3666.343738] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[ 3666.343770] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 3666.343771] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 3666.343799] saa716x_core: disagrees about version of symbol dvb_net_release
[ 3666.343800] saa716x_core: Unknown symbol dvb_net_release (err -22)
[ 3666.343830] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 3666.343831] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 3666.343862] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 3666.343864] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[ 3666.343891] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
[ 3666.343892] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
[ 3666.343918] saa716x_core: disagrees about version of symbol dvb_dmx_init
[ 3666.343920] saa716x_core: Unknown symbol dvb_dmx_init (err -22)
if try with our latest open source driver (https://github.com/tbsdtv/linux_media/wiki)
Patches for 4.9.155-nrj-desktop-1rosa-x86_64 already applied.
make[2]: Leaving directory '/home/user/drivers/media_build/linux'
make -C /lib/modules/4.9.155-nrj-desktop-1rosa-x86_64/build SUBDIRS=/home/user/drivers/media_build/v4l  modules
make[2]: Entering directory '/usr/src/linux-4.9.155-nrj-desktop-1rosa-x86_64'
  CC [M]  /home/user/drivers/media_build/v4l/cec-gpio.o
/home/user/drivers/media_build/v4l/cec-gpio.c: In function 'cec_gpio_probe':
/home/user/drivers/media_build/v4l/cec-gpio.c:199:45: error: 'GPIOD_OUT_HIGH_OPEN_DRAIN' undeclared (first use in this function)
  cec->cec_gpio = devm_gpiod_get(dev, "cec", GPIOD_OUT_HIGH_OPEN_DRAIN);
/home/user/drivers/media_build/v4l/cec-gpio.c:199:45: note: each undeclared identifier is reported only once for each function it appears in
/home/user/drivers/media_build/v4l/cec-gpio.c: At top level:
cc1: warning: unrecognized command line option '-Wno-format-truncation'
make[3]: *** [scripts/Makefile.build:311: /home/user/drivers/media_build/v4l/cec-gpio.o] Ошибка 1
make[2]: *** [Makefile:1523: _module_/home/user/drivers/media_build/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-4.9.155-nrj-desktop-1rosa-x86_64'
make[1]: *** [Makefile:53: default] Ошибка 2
make[1]: выход из каталога «/home/user/drivers/media_build/v4l»
make: *** [Makefile:26: all] Ошибка 2
admsasha
Re: failed setup driver
Postby steven » Wed May 15, 2019 4:58 pm
For the 0330 package please try like this :
#sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
1.wget http://www.tbsiptv.com/download/common/ ... 170330.zip
2.unzip tbs-linux-drivers_v170330.zip
3. tar jxvf linux-tbs-drivers.tar.bz2
4. cd linux-tbs-drivers
5. ./v4l/tbs-x86_64.sh
6. make -j4
7.make install
8.restart
Postby admsasha » Thu May 16, 2019 8:01 am
I did.
#dmesg
admsasha
Postby admsasha » Thu May 16, 2019 8:13 am
try for ubuntu 18.04. Driver don`t build.
Linux sasha-virtual-machine 4.15.0-20-generic #21-Ubuntu SMP Tue Apr 24 06:16:15 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/tda18218.o
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/tda18212.o
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/saa7146_i2c.o
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/saa7146_core.o
  LD [M]  /root/drivers/linux-tbs-drivers/v4l/saa7146.o
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/saa7146_fops.o
  CC [M]  /root/drivers/linux-tbs-drivers/v4l/saa7146_video.o
/root/drivers/linux-tbs-drivers/v4l/saa7146_video.c: In function 'video_init':
/root/drivers/linux-tbs-drivers/v4l/saa7146_video.c:1307:2: error: implicit declaration of function 'init_timer'; did you mean 'init_timers'? [-Werror=implicit-function-declaration]
  init_timer(&vv->video_q.timeout);
  init_timers
/root/drivers/linux-tbs-drivers/v4l/saa7146_video.c:1308:31: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
  vv->video_q.timeout.function = saa7146_buffer_timeout;
/root/drivers/linux-tbs-drivers/v4l/saa7146_video.c:1309:21: error: 'struct timer_list' has no member named 'data'
  vv->video_q.timeout.data     = (unsigned long)(&vv->video_q);
scripts/Makefile.build:332: recipe for target '/root/drivers/linux-tbs-drivers/v4l/saa7146_video.o' failed
make[3]: *** [/root/drivers/linux-tbs-drivers/v4l/saa7146_video.o] Error 1
Makefile:1552: recipe for target '_module_/root/drivers/linux-tbs-drivers/v4l' failed
make[2]: *** [_module_/root/drivers/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.15.0-20-generic'
make[1]: выход из каталога «/root/drivers/linux-tbs-drivers/v4l»
make: *** [all] Error 2
admsasha
Postby admsasha » Thu May 16, 2019 9:45 am
sorry. The driver is installed, but now there are no drivers from other media devices.
admsasha
Postby admsasha » Thu May 16, 2019 10:12 am
kernel 4.15.0-desktop-47.2rosa-x86_64 and https://github.com/tbsdtv/linux_media/wiki That is all right :D
all thanks
admsasha
