using w_scan complains about outdated drivers
Postby eelstrebor » Wed May 24, 2017 11:32 pm
w_scan version 20161022 (compiled for DVB API 5.10)
tbs-linux-drivers_v170330
user@server2:~$ w_scan -fs -s S101W0 -x -l C-BAND -R 0 -X -r 6 -t 2 >> S101W0initial.txt
using settings for 101.0 west SES 1
scan type SATELLITE, channellist 116
output format czap/tzap/szap/xine
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
WARNING: YOU ARE USING OUTDATED DVB DRIVERS.
/dev/dvb/adapter0/frontend0 -> SATELLITE "TurboSight TBS 6923 DVBS/S2 frontend": very good :-))
Using SATELLITE frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'TurboSight TBS 6923 DVBS/S2 frontend' supports
INVERSION_AUTO
DVB-S
DVB-S2
FREQ (0.95GHz ... 2.15GHz)
SRATE (1.000MSym/s ... 45.000MSym/s)
using LNB "C-BAND"
user@server2:~$ dmesg | grep Turbo
[ 11.909769] tbs6290fe: module license 'TurboSight Proprietary' taints kernel.
[ 13.001654] TurboSight TBS 6923 Frontend Attaching...
[ 13.443846] TurboSight TBS6923 DVB-S2 card MAC=00:22:ab:e0:58:04
[ 13.443848] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6923 DVBS/S2 frontend)...
user@server2:~$ dmesg | grep dvb
[ 11.682761] dvb_core: loading out-of-tree module taints kernel.
[ 11.682805] dvb_core: module verification failed: signature and/or required key missing - tainting kernel
[ 12.497634] DVB: registering new adapter (SAA716x dvb adapter)
user@server2:~$ lspci | grep SAA7160
05:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
user@server2:~$ uname -a
Linux server2 4.10.17-041017-generic #201705201051 SMP Sat May 20 14:53:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
user@server2:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
eelstrebor
Re: using w_scan complains about outdated drivers
Postby xiaocao » Wed May 31, 2017 6:21 pm
LNB "C-BAND" should change to -l 5150,5150,5150
w_scan -fs -s S101W0 -x -l 5150,5150,5150 -R 0 -X -r 6 -t 2
xiaocao
Postby eelstrebor » Thu Jun 01, 2017 4:20 am
It didn't make any difference.
eelstrebor
Postby xiaocao » Thu Jun 01, 2017 9:49 am
hi ,
please give me a remote control via ssh connect or teamviewer .i will fix it .
or you can write email to jack@tbsdtv.com .
best regards!
xiaocao
