tbs6922 on TVH
tbs6922 on TVH
Postby hacksat » Fri May 19, 2017 3:01 am
Hello, everyone,
I use tbsa6922 pci card in tvh
My computers are intel i3, INTEL CORE I3 6100 SKYLAKE 3,7GHZ 8GB DDR4, can work whit this computer?
Becouse whit this pc freeze/block all time, 10 second and go down, Have you had this problem? How did you solve it? :?:
hacksat
Re: tbs6922 on TVH
Postby crazycat » Fri May 19, 2017 8:06 am
what drivers installed ?
Re: tbs6922 on TVH
Postby hacksat » Fri May 19, 2017 4:23 pm
Hello, to enable the tbs6922 card on my tvh I had to follow this guide:
https://bitbucket.org/updatelee/v4l-updatelee
And upgrade the BIOS to the latest version of my pc
hacksat
Re: tbs6922 on TVH
Postby hacksat » Fri May 19, 2017 10:23 pm
I use it with European channels
My problem is that I just found out that with a single frequency channel stays online normally for a long time without blocks, as I put another channel of the same frequency MUX jump all over and go to the ground
hacksat
Re: tbs6922 on TVH
Postby hacksat » Sun May 21, 2017 10:55 pm
No one to help me, none of you have any problems with tbs6922?
hacksat
