Two problems
Two problems
Postby zibzib » Sat Oct 08, 2011 8:14 pm
When I change channel which is on other multiplex than previously in kern.log I have messages without message:
Oct  8 13:35:16 XBMCLive kernel: [  270.690184]
Oct  8 13:35:17 XBMCLive kernel: [  271.862435]
Oct  8 13:35:28 XBMCLive kernel: [  283.242154]
Oct  8 13:35:30 XBMCLive kernel: [  284.746425]
Oct  8 13:35:32 XBMCLive kernel: [  287.006455]
Somtimes, when i watch channel A picture stop and i must switch to channel B from other multiplex for a while and back to A to be well. If I did not switch to channel B i get a message of bad signal.
Previously I had 6921 and all was ok. Signal strength and quality is the same.
I use:
last tvheadend (c88a646)
ubuntu 10.04 with linux-image-2.6.32-33-generic
linux-tbs-drivers_110928.zip
Thanks for the reply.
zibzib
Re: Two problems
Postby steven » Sun Oct 09, 2011 10:12 am
Hi zibzib
this is because if you change B to A ,it will lock again,if you do not change it will not lock again,so i think if you use XBMC to lock channel A again,
it maybe ok,you can have a try.
Re: Two problems
Postby zibzib » Sun Oct 09, 2011 2:44 pm
The second problem happens on Hotbird 13E,11393 V,DVB-S,SR 27500,FEC 5/6 channels "TVN...".
If I use xbmc+tvheadend or only tvheadend is the same problem
What about the first problem?
zibzib
Re: Two problems
Postby zibzib » Fri Oct 14, 2011 3:25 am
Today I installed drivers linux-tbs-drivers_111013.zip and first problem was gone, but only first.
zibzib
