kernel 4.9.14 build problem?
Postby eelstrebor » Mon Mar 13, 2017 7:09 am
make && make install was successful on kernel 4.9.14 but the driver isn't working. Here is the dmesg output:
user@server2:~$ dmesg | grep Turbo
[ 18.336359] tbs6290fe: module license 'TurboSight Proprietary' taints kernel.
[ 18.587080] input: saa716x IR (TurboSight TBS 6923) as /devices/pci0000:00/0000:00:1c.7/0000:05:00.0/rc/rc0/input18
[ 18.587152] rc0: saa716x IR (TurboSight TBS 6923) as /devices/pci0000:00/0000:00:1c.7/0000:05:00.0/rc/rc0
user@server2:~$ dmesg | grep dvb
[ 18.587370] DVB: registering new adapter (SAA716x dvb adapter)
[ 18.587398] [<ffffffffc0586eca>] ? dvb_dmx_init+0x3a/0x2a0 [dvb_core]
[ 18.587400] [<ffffffffc0586eca>] dvb_dmx_init+0x3a/0x2a0 [dvb_core]
[ 18.587402] [<ffffffffc0872ad1>] saa716x_dvb_init+0x171/0x580 [saa716x_core]
[ 18.587406] [<ffffffffc08efd76>] saa716x_tbs_pci_probe+0x1a6/0x2f0 [saa716x_tbs_dvb]
[ 18.587420] [<ffffffffc08f0040>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 18.587423] [<ffffffffc08f0040>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 18.587426] [<ffffffffc08f0063>] saa716x_tbs_init+0x23/0x30 [saa716x_tbs_dvb]
[ 18.587562] Modules linked in: rc_tbs_nec(OE) ghash_clmulni_intel saa716x_tbs_dvb(OE+) tbs6982fe(POE) tbs6680fe(POE) stv090x tbs6923fe(POE) aesni_intel tbs6985se(POE) tbs6928se(POE) tbs6982se(POE) tbs6991fe(POE) tbs6618fe(POE) tbs6983fe(POE) saa716x_core(OE) snd_soc_rt5640 tbs6922fe(POE) tbs6928fe(POE) tbs6991se(POE) rt2800pci(+) snd_soc_ssm4567 snd_hda_codec_realtek snd_hda_codec_hdmi snd_hda_codec_generic snd_soc_rl6231 snd_soc_core aes_x86_64 tbs6290fe(POE) rt2800mmio lrw snd_compress snd_hda_intel glue_helper rt2800lib ir_lirc_codec(OE) lirc_dev(OE) rt2x00pci rt2x00mmio ir_mce_kbd_decoder(OE) rt2x00lib mac80211 ir_sony_decoder(OE) ir_jvc_decoder(OE) snd_hda_codec ac97_bus ir_rc6_decoder(OE) snd_hda_core ir_rc5_decoder(OE) snd_pcm_dmaengine snd_hwdep ir_nec_decoder(OE) dvb_core ablk_helper cryptd
[ 18.588370] [<ffffffffc0872f1a>] saa716x_dvb_exit+0x3a/0xf0 [saa716x_core]
[ 18.588387] [<ffffffffc08efd96>] saa716x_tbs_pci_probe+0x1c6/0x2f0 [saa716x_tbs_dvb]
[ 18.588521] [<ffffffffc08f0040>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 18.588553] [<ffffffffc08f0040>] ? load_config_tbs6923+0x10/0x10 [saa716x_tbs_dvb]
[ 18.588587] [<ffffffffc08f0063>] saa716x_tbs_init+0x23/0x30 [saa716x_tbs_dvb]
eelstrebor
Re: kernel 4.9.14 build problem?
Postby xiaocao » Tue Mar 14, 2017 11:58 am
hi ,
please delete media dir and reinstall the driver.
1. ver=`uname -r`
rm -rf /lib/modules/$ver/kernel/drivers/media/
2. make install
3. reboot
best regards!
xiaocao
Postby crazycat » Wed Mar 15, 2017 3:57 am
install open-source drivers :)
