Open-source driver - Make config - Right choices?
Postby Golffies » Thu Aug 22, 2019 2:51 am
Hello Steven,
When building the open-source driver, make config gives access to a lot of option, usefull for selecting the devices which to build a driver for. May you give a short list of the mandatory options which have to be switched to 'Yes', when compiling drivers only for the TBS8922?
The TBS' GitHub wiki instructs to use make allyesconfig. This makes no sense when building the driver for one single model only. Actually, make allyesconfig triggers the build to be completed for all possible DVB devices. It can only bloat the system and take too much time to complete.
Thank you.
$ make config
make -C /home/interface/tbsdtv/media_build/v4l config
make[1]: Entering directory '/home/interface/tbsdtv/media_build/v4l'
/lib/modules/4.15.0-58-generic/build/scripts/kconfig/conf ./Kconfig
* V4L/DVB menu
Enable drivers not supported by this kernel (VIDEO_KERNEL_VERSION) [N/y/?] (NEW) n
* Remote Controller support
Remote Controller support (RC_CORE) [M/n/y/?] n
* Multimedia support
Multimedia support (MEDIA_SUPPORT) [M/n/y/?] n
* Sound card support
Sound card support (AUDIO_SUPPORT) [N/y/?] (NEW) n
* Misc devices
Misc devices (MISC_DEVICES) [Y/n/?] n
* Staging drivers
Staging drivers (STAGING) [N/y/?] n
# configuration written to .config
./scripts/fix_kconfig.pl
make[1]: Leaving directory '/home/interface/tbsdtv/media_build/v4l'
Golffies
Re: Open-source driver - Make config - Right choices?
Postby steven » Thu Aug 29, 2019 2:28 pm
Hi Sir
Thanks for your good advice ,this is for all of customer easy to compile the driver if you are professinal user you can manual
choose the driver you want to use
Postby Golffies » Thu Aug 29, 2019 2:38 pm
Thank you for your answer,
may you point me to the documentation for the professional that explains which flags to switch to yes in the configuration file, in order to build the driver for your 8922 card only? Or just give me the instructions here and now?
Regards.
Golffies
