[ Moderator Control Panel ]
by imperia » Mon Apr 08, 2013 2:32 am
- Code: Select All Code
CC [M] /usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.o
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c:279:43: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__devinitdata'
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c: In function 'isapnp_fmi_probe':
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c:291:9: error: 'id_table' undeclared (first use in this function)
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c:291:9: note: each undeclared identifier is reported only once for each function it appears in
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c: At top level:
/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.c:285:1: error: '__mod_isapnp_device_table' aliased to undefined symbol 'id_table'
make[3]: *** [/usr/local/src/tbs/linux-tbs-drivers/v4l/radio-sf16fmi.o] Error 1
make[2]: *** [_module_/usr/local/src/tbs/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-source-3.8'
make[1]: Leaving directory `/usr/local/src/tbs/linux-tbs-drivers/v4l'
make: *** [all] Error 2
imperia
by steven » Sat Apr 20, 2013 9:19 pm
Hi imperia
Do you have fixed this problem if not,
Can you send your detail information to our linux euro_support#tbsdtv.com,
we will answer you as soon as possible.
kind Regards
