Qbox S2 and fedora 15 64 bit driver issues.
Postby Sat4all » Mon Sep 19, 2011 2:47 pm
I have problems with the Qbox S2 on Fedora 15 64bit - default kernel.
When scanning, halfway true the driver/device crashes. I have to take the power of the Qbox S2. Just a reboot is not sufficient.
The TBS 6925 which i tested in the same system, same OS, same driver does work just fine.
Cheers,
Michel
Sat4all
Re: Qbox S2 and fedora 15 64 bit driver issues.
Postby steven » Wed Sep 21, 2011 10:50 am
Do you have tested the new driver and the older driver?both not ok?
and you can contact with our euro_support@tbsdtv.com,he will give you an answer as soon as possible.
