TBS5922 Blind scan low S/R Problem
Postby kazimali25 » Sun Apr 08, 2012 5:56 pm
I have TBS5922 device.I have one probleem that TBS5922 blind scan program not scaned any TP which have symbol rate less then 1600.my other blind scan receiver tuned many transponder S/R less then 1600.
kazimali25
Re: TBS5922 Blind scan low S/R Problem
Postby tempo » Sun Apr 08, 2012 6:09 pm
The same with TBS 6922 card. Seems it is hardware restriction of TAS2100 demod chip in blindscan mode.
tempo
Postby starman345 » Sun Apr 08, 2012 7:26 pm
Same situation with TBS 8922
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby steven » Tue Apr 10, 2012 9:04 am
Like tempo said that it is the hardware restriction.Can not do it by our software.
