recently I have bought a TBS 5922 and it works fine so far under WIndows 7 x64. The only thing which does not work is the remote.
The driver (2.0.2.7) istalled the HID-Interface which I can see in the Device Manager. But so far there is no way, that I can map inputs to any actions.
I searched the web on how I could map inputs to actions and it seems, that there is a software from TBS which should do that (VHID-Tool). But after installations it tells me during startup that there is no TBS product installed and quits.
I also tried TBSViewer but the remote is not recognized as well. At least I can see, that the TBS 9522 is receiving a signal, because a weak light is lighting up when I press the remote.
So my question is, how do I get the remote work under windows 7 x64?
The final goal is to use it with mediaportal, which should work through using the "General HID" interface.
Any help is very much appriciated.
Regards
Philipp
