problem in windows server 2008 r2 64 bit
Postby toughcanny » Thu Jan 05, 2012 11:30 pm
I bought 5922 USB Box, but I am running across many problems.
I am using Windows server 2008 R2 Enterprise 64 Bit.
Driver was successfully installed and I can see TBS 5922 USB DVBS/S2 BDA in Sound Video and Game controller section in Device Manager.
I installed progdvb, dvb dream, tbs ip data, tbs blind scan softwares, but all of them are not working
For tbs-ip after starting it, it give error TBS IP Service has stopped working
detail error for this is
Problem Event Name: APPCRASH
Application Name: TBSIP-Update.exe
Application Version: 3.0.3.2
Application Timestamp: 4e40c25c
Fault Module Name: TBSIP-Update.exe
Fault Module Version: 3.0.3.2
Fault Module Timestamp: 4e40c25c
For tbs-5922 blind scan, error is TBS Blind Scan tool has stopped working
Application Name: TBS5922-BlindScan.exe
Application Version: 3.0.0.6
Application Timestamp: 4e291895
Fault Module Name: TBS5922-BlindScan.exe
Fault Module Version: 3.0.0.6
Fault Module Timestamp: 4e291895
Exception Code: c0000005
Exception Offset: 0000427e
For dvb-dream, its giving error General Hardware Fault
Detail error is
General Hardware Fault!
Cannot Initialize DVB Hardware! ErrorCode:2
Application will work in Offline Mode
OK
For prog-dvb, it is giving following error
Error
[{BDA} TBS 5922 USB DVB-S2 Tuner] Device not started!
OK
and in TV Source / Device section BDA TBS 5922 comes to red.
How can I use this device? I can't view any channel / any thing.
Atleast progdvb should work. I installed both 32 and 64 bit of progdvb, new as well old version
Thanks.
toughcanny
Re: problem in windows server 2008 r2 64 bit
Postby bob » Fri Jan 06, 2012 9:36 am
Please download the BDA patch files from this link:
http://hotfile.com/dl/140163683/d04c199 ... a.rar.html
The original version of windows server 2008 don't support BDA driver.
Regards!
bob
Postby toughcanny » Sat Jan 07, 2012 5:06 pm
Thanks for the files. After installing, it works for following
dvd dream working fine
tbs blind scan working fine
tbs ip data is not giving error but its interface is not showing so it is still not working
progdvb 64 bit version is still giving same error device not started
prog dvb 32 bit version is started but much slow and video showing with much garbage and switching between channel takes much time and progdvb goes in not responding state.
toughcanny
