TBS5922-Scan Result
TBS5922-Scan Result
Postby MrAB » Wed Nov 30, 2011 10:23 pm
Recently i am facing some issues with my product (TBS5922).
When i scan a particular Sat, the channel name appears wrongly and repeatedly same channel name.... Some chnls names (only name, the chnls is working fine) are from different sat... :(
Also, many chnls are appearing as "Nameless" ....
How can i troubleshoot this issue...
Pls help. Thanks.
MrAB
Re: TBS5922-Scan Result
Postby steven » Thu Dec 01, 2011 10:43 am
Hi MrAB
If you can get the channel but it appearing as "Nameless",it means that you can not get the SDT table(which is for Channel Name),
The signal is not good enough,So can you move your dish to get a better signal.
And Do you have used the latest driver which have fixed some bug.
